Post by nigel on Mar 20, 2015 13:39:12 GMT
Excellent find I will kerob1labs see if it can be included in the Doc's board of the Tech Section for future reference for all that are interested.
nigel
Post by Johnsto on May 18, 2015 8:05:30 GMT
Ok, small update. I have fitted the seats with 10.9 rated bolts, gear linkage, covered the internal panels in carbon fibre wrap, wilwood front calipers, ordered rear calipers and still plugging on with the electrics. I will update with some pics tonight. Still not sure I have the right track rod ends, they are rs2000 ends but the thread just doesnt seem long enough!
Post by Johnsto on Jun 5, 2015 18:11:26 GMT
I have tried my calipers and they don't seem to fit, more like the carriers are the wrong ones. I have the standard focus calipers and carriers. The discs measure 280mm, I now know these to be st170 discs! (bought the car part built). What is the best way forward??
Post by mawdo81 on Jun 5, 2015 19:08:14 GMT
Sell me the discs (for my front) and buy new discs.
Post by Johnsto on Jun 5, 2015 19:41:38 GMT
I may well do that, but if I remember correctly, when I tried to strip the rear assembly down, a few months back, they were attached with more force than known to man!! I will attempt removal some time next week and let you know James.
Post by Johnsto on Jul 8, 2015 7:16:55 GMT
Ok rear st carriers sourced from e of the bay, £20, bargain. Electrics wired from scratch, just the clock to add for the immobiliser led then I shall be hooking up the battery to test all systems . I would do it today but waiting on delivery of rear lights and side indicators.
Post by Johnsto on Jul 12, 2015 23:29:07 GMT
All lighting systems are go. I have used the original focus switches. Will I need to cover up the headlight adjustment bit for IVA? On to getting the engine fired up I am installing the rad hoses (from ASH). Order placed and awaiting delivery. Next will be the aux belt. Anyone have an aux bracket they wanna sell me? Pretty please.
Post by Johnsto on Oct 9, 2015 17:37:32 GMT
I've been quiet for abit, just plodding on in my spare time. Went for the engine start today, FAIL. First a petrol leak from the rail, nothing major just needed to tighten the connection, at least I know fuel is reaching the injectors She turns over but no go. Checked for a spark at the plugs, one spark then nothing on no1. Head scratching time. Checked engine ground, seems ok, Ordering a diagnostic reader so I can see what the ECU is up to. Pats seem ok, key in and turn, lights up the immob LCD and then it goes out as it should. I will update the diary with some pics of the build soon, busy busy n all that.
Post by Johnsto on Oct 10, 2015 9:12:47 GMT
As promised a couple of updated pics.
Floor and side panels covered in Cabon Fibre wrap, easily renewable as it wears.
Post by Johnsto on Oct 10, 2015 9:26:30 GMT
As you can see in this pic, I have fitted the seats (using 8.8 bolts and crush tubes). Also the front wings are in the incorrect position and will need to be moved to accomadate full lock. The radiator fan is a pull type so will need to switch that over and the lights will be raised slightly on some extensions for IVA. I do need to fit front fogs, due to using the focus light switch, but these will be attached under the main headlights once I raise them up.
Post by Johnsto on Oct 10, 2015 9:35:16 GMT
More to follow shortly...........any requests of particular parts to be photographed will be accommadated Also if you see any glaringly obvious mistakes/IVA fails you'd like to point out that would be appreciated.
Post by nigel on Oct 10, 2015 10:00:19 GMT
Great pics John, what radiator have you used?
nigel
Post by Johnsto on Oct 10, 2015 10:26:04 GMT
Hi Nigel, it's a Seat Toledo 1.6 rad (Nissens 651511)
Post by Johnsto on Oct 10, 2015 10:27:50 GMT
Rear light, specials from ebay, £25 trailer lights, e marked so should be fine.
Post by Johnsto on Oct 10, 2015 10:33:58 GMT
Aux belt tensioner fitted as per Guy's and Martin's builds, allows the tensioner to work as it should. Used a 1353 belt, fits snuggly.
Also made an idler bracket out of 7mm angle iron and a 4 1/2" grinder It ain't going nowhere.
