Post by Johnsto on Mar 13, 2015 9:46:36 GMT
I am using the Focus clocks. I will be ordering the dash pod to suit them from Mr Mills. I will reusing the Focus light switch also. This will mean I need a front fog light.
Post by mawdo81 on Mar 13, 2015 11:17:38 GMT
Post by kerob1labs on Mar 13, 2015 13:02:59 GMT
Post by mawdo81 on Mar 13, 2015 17:52:11 GMT
Good find
Post by Johnsto on Mar 13, 2015 23:10:12 GMT
Nice. I don't mind having fogs. Will review the situation after she's on the road.
Post by Johnsto on Mar 17, 2015 13:04:44 GMT
Post by Johnsto on Mar 17, 2015 13:06:25 GMT
Small issue with getting the torque mount to line up. Am I suppose to use a custom link? 2.0 Zetec with ib5 by the way.
Post by mawdo81 on Mar 17, 2015 13:06:52 GMT
Hmm, which engine & gearbox?
Post by Johnsto on Mar 17, 2015 13:07:49 GMT
Corrective keyboard, grrrrr. Corrected
Post by mawdo81 on Mar 17, 2015 13:09:33 GMT
Sorry, posts crossed in cyberspace. How are the driveshaft sockets on the gb aligned with the hubs?
The Zetec is naturally at an angle in the Focus, are you sure its not too vertical?
Post by Johnsto on Mar 17, 2015 13:21:08 GMT
I'll get a picture posted.
Post by Johnsto on Mar 17, 2015 13:27:52 GMT
This is the angle after I've pulled the link to fit in place. Drive shafts line up much better. Is this the kinda angle you were thinking James?
Post by mawdo81 on Mar 17, 2015 14:06:30 GMT
Doesn't look too bad to me. Have a look on some of the other Sonic & Rocket posts, you'll get a view of others set up.
Also given how many focus are around I'd bet you could get a gander at a 1.8 at a second hand lot near you and verify how it compares.
Post by airforceone on Mar 17, 2015 16:10:03 GMT
Sorry can't see the picture at the minute due to looking on the works computer, pictures blocked.
Not sure how the engines are set up between the Rocket and the Sonic as I believe there is a bit more space in the Sonic engine bay. You should have a slight angle forward when the link is fitted. Possibly 5-10 degrees.
Post by mawdo81 on Mar 17, 2015 16:21:55 GMT
Ha, if the photo is completely level (and it looks it given the window frame in the background, then I make it between 7 & 9 degrees, so sounds like you're fine.
