Post by lhintze on Jan 5, 2015 16:22:40 GMT
Post by steadfast on Jan 5, 2015 16:28:00 GMT
I've often wondered about this too, mine is unused. I would guess that it would be for a shoulder belt... Quick question, what is this bracket for? (In the upper right corner) I'm not sure what bolts to this.
Post by nigel on Jan 5, 2015 19:49:46 GMT
Yes steadfast, I agree that is the mounting bracket for attaching a seat belt inertia reel. Picture below Page 15, from the UK Exocet Build Guide, showing it fitted, to MEV's original demonstrator. nigel
Post by lhintze on Jan 5, 2015 19:53:35 GMT
Warren verified that it is for a 3 point system, they put them on all chassis so the rear bulkheads will all be the same also.
Post by greg on Jan 5, 2015 19:53:42 GMT
Taken from the GRMS thread.
Post by linuxd00d on Jan 5, 2015 21:16:53 GMT
Hah, I had looked all over that guide EXCEPT the bodywork page, since I don't even have bodywork yet. Thanks I gotta make sure I have that bracket. If I do, it's in one of the boxes with small parts. It didn't come zip tied to main exo frame like the square plate holding the steering column did.
Post by pincherrn on Jan 5, 2015 22:35:29 GMT
Hi guys. Would the cluster brackets work on a RHD too. Would you send a set to UK and what would it cost. Or could a drawing be supplied to make my own. Loving the changes being made to the kit to make it easier to get a high quality finish. The interior panelling looks great. The tunnel and floor / bulkhead panels have been a nightmare on mine.
Nice work guys.
Colin
Post by steadfast on Jan 6, 2015 1:37:21 GMT
The cluster bracket should work on the UK version. I'd shoot a message to Kevin or email Exomotive.
Post by lhintze on Jan 6, 2015 2:06:15 GMT
Post by steadfast on Jan 6, 2015 4:18:32 GMT
Great progress, and it is looking great! Your garage is so clean! I'm fairly certain that once you get the slim fans, you will have to wire them together. The second fan (passenger side) won't turn on if I remember correctly.
Post by lhintze on Jan 6, 2015 10:53:59 GMT
Thank you, the long wait has payed off. I will look into wiring them correctly, is there a reason the passenger side is different?
Post by einy on Jan 6, 2015 14:17:17 GMT
IIRC, one fan is triggered by the ECU for engine cooling purposes, the other by the air conditioning being turned on. I recall seeing info on Miata.net about wiring the AC triggered fan for use in engine cooling ...
Post by ImprobableConstruct on Jan 6, 2015 14:32:34 GMT
That looks so sweet! I ordered the mishimoto fan shroud kit from Amazon. Price was as good as anywhere and it was prime! I was not sure if I should order the NA kit for fitment or the NB model for the wiring but it looks like the wires need to be spliced either way so I went with the NA to match the NA radiator.
Post by lhintze on Jan 6, 2015 15:15:01 GMT
I am going to try and modify the OEM fans to fit, it looks like it is only hitting on the sway bar, I will try to cut part of the fan support out. If not, I will get the Mishimoto fan shroud kit. I have an idea of a way to get the radiator mounted to the supplied brackets, just need to do it now. I will look at wiring them together when I start with the wiring harness.
Post by einy on Jan 6, 2015 19:11:45 GMT
Seems like there are multiple 'opinions' out there on Miata.net and others on how best to wire the fans to work at the same time for engine cooling. Simplest is the wire the black/blue wire that supplies power to the AC fan to the yellow wire that supplied (ECU controlled) power to the normal engine cooling fan. "Risk" in that method is a higher current draw vs. what the engine cooling fan is designed to deal with (now running two fans instead of one). Alternative suggestion (that makes sense to me) is to use the power leads that normally go to the engine cooling fan as the signal to a new (adequately rated) relay, and the output from that relay to now power both fans. If you have a pre OBD-II car (which is what I have), you can test the fans coming on by running a jumper between the "GND" and "TFA" terminals in the diagnostic connector. I don't know how to test on an OBD-II equipped car, sorry to say.
