Post by mabbs on Jan 18, 2011 20:25:51 GMT
Very clean. Can I ask how you managed to keep the grease off the arms when you were fitting the crush tubes. I'm covered in the stuff Lots and lots of kitchen roll Wife has mentioned the amount I am using as well
Post by Kevin Patrick on Jan 18, 2011 20:31:04 GMT
Gorgeous build. Your attention to detail is inspiring. Keep the updates coming!
Post by The Joker on Jan 18, 2011 21:33:14 GMT
Fantastic build Mabbs...looking forward to seeing this one.
Andy888
Exocet Builder
Post by Andy888 on Jan 19, 2011 11:37:50 GMT
This is fantastic, keep up the good work and the pics!!
Post by damien31 on Jan 19, 2011 12:24:42 GMT
It's a fabulous job you doing here! It is very clean, with very good ideas, and detailed construction. And beautiful picture to see it in detail. It gives me many ideas for my future rocket. Very good continuation.
Post by mabbs on Jan 19, 2011 16:27:50 GMT
Thanks for the kind words guys. Should be making a nice impact on the build over the next couple of months so lots more pics to come.
Jon
Post by mabbs on Jan 23, 2011 18:42:48 GMT
Post by Scott on Jan 24, 2011 8:24:00 GMT
Looking great Mabbs,
Dont forget to cover that plastic adjuster nut on the rack,,,,
Scott
Post by mabbs on Jan 24, 2011 19:56:12 GMT
Looking great Mabbs, Dont forget to cover that plastic adjuster nut on the rack,,,, Scott Thanks Scott. Was going to push over a domed cover - when I find one !!
Post by mabbs on Jan 30, 2011 18:55:59 GMT
Looking great Mabbs, Dont forget to cover that plastic adjuster nut on the rack,,,, Scott Ta da ;D I assume this is what you meant Scott ?
Post by mabbs on Jan 30, 2011 19:02:46 GMT
Whilst waiting for some main parts to continue the build I thought it would be a good time to get this job out of the way: Decided to model-up and extend the steering column cover. From this will make a high-temp tool and pre-preg a carbon fibre part.
Post by mabbs on Jan 30, 2011 19:14:22 GMT
Started the top part of the cover today: Bottom half of this part still to do then lots of sanding to finish this as the pattern for the carbon fibre tool
mightylad
.....Mighty MEV Rocket.....
Post by mightylad on Feb 2, 2011 19:19:09 GMT
Excellent build Mabbs,
I like the attention to detail! you'll soon be on the road with a build to be proud of!
Cheers, Ol
Post by exo on Feb 4, 2011 21:20:33 GMT
is that a pedal from Joker to match the Wilwood pedal box?
Post by mabbs on Feb 8, 2011 15:23:29 GMT
is that a pedal from Joker to match the Wilwood pedal box? Yes, had it powder coated black and purchased some stick grip tape for the pedal face. Jokers pedal is good quality item and it is now improved with a roller bearing.
