Post by bingo on Apr 23, 2014 12:49:38 GMT
Best start updating this build thread, it was almost at the bottom of page two. The car is booked in with RTR for its IVA on the 2nd May, best get updating....an the other small significance of finishing.
Post by bingo on Apr 23, 2014 12:54:29 GMT
To build up the front of the car.....
Rad in position, needed a bit of adjusting/cushioning, so made use of the offcut from the coolant pipes.
Not sure about the rad position as its very tight , even though the rad has been moved 50mm to the front.
Front grill in positioned, used 6mm stainless mesh, anybody have any thoughts on airflow, now the bottom if covered in??
Post by bingo on Apr 23, 2014 12:55:30 GMT
sides all fitted
Post by bingo on Apr 23, 2014 12:57:16 GMT
I've CORved this before in a separate thread, a couple of pics of the terrible COVER OR RANDOMNESS, I would make your own, but have heard rumours that RTR have redisgned
Post by bingo on Apr 23, 2014 13:01:39 GMT
I sourced my coolant pipes from JS performance in Lincoln
www.jsperformance.co.uk/
These guys are amazing, I had a quote from ASH of nearly £200 as I wanted the bright green. These guys did them all for £100. They also left them oversized so that I could cut down to the length required.
Very tight on the fan housing, need to trim the housing a little to fit the bulkhead neatly.
Post by bingo on Apr 23, 2014 13:03:10 GMT
Bulkhead fitted by the coolant pipes are incredibly tight, need to have a rethink
Post by mawdo81 on Apr 23, 2014 13:41:26 GMT
Where is the air going to go once its through the rad/fan? It looks like there is no escape for it, which will surely hinder your cooling?
Post by bingo on Apr 23, 2014 13:55:30 GMT
Where is the air going to go once its through the rad/fan? It looks like there is no escape for it, which will surely hinder your cooling? There is a slot in the floor under the fan housing, its blue at the chassis is sat on some blue foam
Post by hightower on Apr 23, 2014 14:29:15 GMT
Coolant pipes look good bingo I've got some to buy for mine.
Post by roadtrackrace on Apr 23, 2014 17:04:48 GMT
Bulkhead fitted by the coolant pipes are incredibly tight, need to have a rethink We always fit the fan in front of the radiator which gives room for the coolant pipes. By blocking off the floor, you will find that most of the heat from the rad will come under the bonnet and toast your legs which is lovely on a typical British day. Fabulous looking build though, can't wait to see it here at RTR :-)
Post by bingo on Apr 24, 2014 7:22:47 GMT
We always fit the fan in front of the radiator which gives room for the coolant pipes. By blocking off the floor, you will find that most of the heat from the rad will come under the bonnet and toast your legs which is lovely on a typical British day. Fabulous looking build though, can't wait to see it here at RTR :-)Thanks for the kind words, I am now using a "Pushing" fan and is mounted on the other side. I was uncertain about the floor to was a bit of a sheep, at least it can be easily removed if not needed.
Post by bingo on Apr 28, 2014 15:13:06 GMT
SHE IS ALIVE!!!!!
Post by bingo on Apr 28, 2014 15:20:01 GMT
Decided to go for something a little different with my tunnel, heard a lot of discussions regarding the short bit been at the front or the back. So decided to have a full height section at the front that will be fixed in place. This will house my dash2 and the necessary buttons. I am also hoping to line this out to create a glove box type arrangement that is accessible from under the bonnet. I need some place to store my handbag!!!!!
What do you think??
Post by bingo on Apr 28, 2014 15:21:12 GMT
Post by bingo on Apr 28, 2014 15:25:05 GMT
Standard wrap in carbon, its real honest!!!, with the holes cut ready to accept dash2
You will notice the holes around 150mm higher, these are for a couple of angles that will hold the base of my glove box
