Post by bingo on Apr 28, 2014 15:26:13 GMT
You will also notice the fan as disappeared, decided to install a "Push" fan in front of the rad to give a little more room behind the rad
Post by minuit on Apr 28, 2014 15:39:27 GMT
Dash looks great; you might as well install vents and have heat in the cabin!
Post by airforceone on Apr 28, 2014 16:13:00 GMT
Looking good.
Just be careful and make sure you can actually reach the buttons on the centre console when your strapped in. As yours is a straight/flat faced console if you have the buttons too low you will struggle to reach them.
That's why I ended up with an angle on mine, I originally had a flat faced console but as my seat was positioned right back the buttons were just to far away when I had the racing harness done up tight.
Post by ade on May 7, 2014 16:01:04 GMT
How did the IVA go? I can't believe how quickly you've built it.
Post by bingo on Jun 27, 2014 15:29:24 GMT
Can't believe I've found my thread on page 3!!!!!, The Rocket has been at RTR for nearly eight weeks waiting for its IVA. Which will be on Monday next, so hopefully Tuesday there will be a tearful reunion.
Best get my arse into gear and update my build thread
Post by Deleted on Jun 27, 2014 15:56:26 GMT
Build update will consist of bits falling off???
Post by bingo on Jun 27, 2014 17:27:28 GMT
Never Steven I am a law abiding citizen
Sent from my SM-N9005 using proboards
Post by kingofthetwisties on Aug 3, 2014 15:26:43 GMT
Very nice angles on the steering column. If any body needs the dimensions of the extension shaft a have a drawing somewhere, also have the part no of the bearing and dimension for the location. The shaft is 500mm piece of 20mm stainless round bar. with a 17mm hex machined on one end, the other is machined to 16mm then flats machined at 14mm....PERFIK FIT Hi Bingo If you still have the above info for extending the steering column I would be keen to take a look. I'm just working out what I need on mine now
Post by casesensitive on Jan 21, 2015 12:06:11 GMT
Hi bingo, do you have any pictures of bonnet hinge from the driver's seat? I'm trying to figure out if it'll protrude into the cabin. Is it in it's 'folded' position when the bonnet is closed? As in, does it open to lift the bonnet or close to lift the bonnet? cheers! Also, did you fit instruments into the bonnet's face? Do they snag when the bonnet is lifted?
Post by deanohonda on Jan 21, 2015 14:58:02 GMT
hi there bingo can not reply as he on a ban from the forum if u pm me ur phone number i can get him to give you a call hope this helps DEANO
Post by casesensitive on Jan 22, 2015 0:38:35 GMT
Ha ha.. banned? Did he say something about the COR? :-) PMing
Post by deanohonda on Jan 22, 2015 8:04:59 GMT
Not here but not forgotten lol ;-)
Post by casesensitive on Jan 23, 2015 15:59:09 GMT
Does he also reside in the Other Place?
Post by deanohonda on Jan 23, 2015 17:41:24 GMT
the darkside is strong in this one lol ;-)
Post by bingo on May 13, 2021 20:23:06 GMT
Well sold the bugger, just posting to put on page one, so the new owner can it
