Post by jon on Jan 23, 2016 16:40:17 GMT
My tank, OEM from a 1990 NA donor, was 1-7/8". I thought they were all that way, but maybe not.
Post by einy on Jan 24, 2016 13:29:07 GMT
Post by thestig on Jan 25, 2016 1:33:29 GMT
They do not have them in stock and they are 1-2 months out. I have checked around everywhere and they seem to be the only place that makes a fuel safe reducer. The other option is to use a piece of exhaust pipe and have that necked up or down to fit correctly.
Post by gwnwar on Jan 25, 2016 6:49:42 GMT
Muffler shop seems the way to go. They might be able to do a small bend too with the sizing if needed..
Post by einy on Jan 25, 2016 23:46:53 GMT
They do not have them in stock and they are 1-2 months out. I have checked around everywhere and they seem to be the only place that makes a fuel safe reducer. The other option is to use a piece of exhaust pipe and have that necked up or down to fit correctly. Bummer ... When I was at that stage I looked and looked for alternatives to validate their pricing, and didn't find anyone else who carried those types of specialty parts.
Post by jmills on Jan 26, 2016 3:39:16 GMT
TheStig, there is a source for these reducers... just not locally. I ordered both reducer and 2" flex hose from the UK. www.carbuildersolutions.com/uk/ Worked well for my build, shipping was surprisingly fast!
Post by papabear on Jan 26, 2016 14:20:05 GMT
Post by steadfast on Feb 5, 2016 4:25:31 GMT
Finished up the cover, looks pretty good (need to get all black bolts). I cracked a corner off, but not the end of the world. Thanks Jon for the dimensions! I'll be doing turbo install tomorrow. Looking forward to it.
Post by einy on Feb 5, 2016 12:10:09 GMT
Interested to find out what you used for mirror mounts .... and for mirrors, while I'm "asking" ??
Post by steadfast on Feb 5, 2016 16:06:21 GMT
Post by jon on Feb 5, 2016 20:56:37 GMT
How did you end up mounting the plexiglass windshield?
Post by lhintze on Feb 5, 2016 22:17:39 GMT
good luck on the turbo kit, can't wait for mine!
Post by steadfast on Feb 6, 2016 6:58:07 GMT
Well started off with a new TV setup for the garage: The idea is to install these first But first a drink Installed the new injector clips Removed crap I don't need I already tapped the oil pan when I had the motor out so I just put on the barbed hose adapter. I realized I went hog wild with the sealant when installing the oil pan. Tomorrow I tackle this
damn packing peanuts
Post by steadfast on Feb 7, 2016 3:35:27 GMT
Got the following done today:
turbo mounted oil lines ran water lines ran IC pipes ran
I found that the Mishimoto NA radiator, coolant reroute, and intercooler pipes don't work together. I have just purchased a new radiator that allows for the coolant inlet to be moved to the passenger most side. That should solve my issues. I have a custom dash on the way too, more to come on that next week.
Post by steadfast on Feb 7, 2016 18:50:40 GMT
Dash is in. Thanks again to Jon for the idea. TAP Plastics is right down the road from my house. I stopped in there with a few drawings. I had them create a dash with cut outs for my dash display and 3 gauges. The long piece goes on right side of the steering wheel, the short piece goes on the left. The digital dash opening is the perfect size.
