Post by casesensitive on Dec 16, 2013 13:55:25 GMT
It's a carBy the loosest definition of the Moggers' Code, if it has 4 wheels attached, it's a car...
Post by Paul (madeye) on Dec 16, 2013 17:39:49 GMT
I like your paddle shift levers :-) :-)
Post by casesensitive on Jan 12, 2014 22:32:18 GMT
Test fit of the engineThis one has me a bit nervous; when I ordered my kit, I was at pains to remind RTR that I can't fabricate new mounts or weld, so the engine and gearbox mounts would have to fit the ST170 engine and getrag mounts or I was up a smelly creek without a paddle. In short, it fits! Not much room for bouncing around, but it just about fits. In order to get it in, I found I needed to take off or loosen; - Take off the engine mount (right on Rocket)
- Take off the gearbox mount
- loosen the cover from torsion link (middle mount)
- drill out the engine mount receiver hole 12mm
Engine mount not fitting in its hole. Video of the process is a bit long to be bothered posted here, but I'll do a short version of it when I get a minute. And then straight out again, still a fair bit to go before it'll go in permanently! I undid these 2 13mm nuts a couple of turns to give enough room to get a bolt in Bit tight Almost certainly too tight (about 6/7mm) In!
Post by casesensitive on Jan 12, 2014 23:38:27 GMT
Fitting the seats / rail extensionsSo my seat rails are slightly too short to span the provided bars, so I decided to buy some 8mm mild steel bars to go between them and act as a reinforcement. I've done pretty much exactly what jacksdad has done. I bought some 8mm internal diameter (12mm outer) stainless steel tube with a good thick wall to act as crush tubes and washers to raise the seats off the rails. 15mm spacers to lift seat off the rails I laid out the bars to support the seat rails, with a small tack weld to hold it in place. If I was doing this again, I'd have just stuck with clamps. Ended up grinding the weld off anyway. Washers lift the seat so the locking mechanism clears. At Paul (madeye)'s suggestion, I cut up some scabby ol' 2mm angle, making 4x 30mm x 40mm and 4x30mm x 30mm (back and front) load spreaders. I drill them with the 3, 5 and cobalt bits as usual. I stuck them in between the washers and the seat to help spread my lard more evenly, reckon they'll be fine. I have since sprayed the washers and spreaders black so the seat and rails looks as one. I then cut 8x 31mm lengths for the crush tubes, rounding the edges with a grinder to form a shape that'd match the inside of the support bar. I filed down the rough edges, and had to use a round file to deburr the inside so an M8 bolt would still go through. I marked the drill points with a punch tool, then drilled 3, 5, and 8mm holes right through the 8mm bar, into the cross-member and out the other side. I widened the top hole to 12mm so the crush tube would go into the tube without coming out the other side. To ensure it fit, I pushed an M8 bolt up through the lower hole, and dropped the crush tube onto it, and banged it home with a hammer. Note the mark on the upper side to let me know which way the chamfer on the inside goes Flapper disc to smooth 3 holes in each bar, 2 to the cross-members (front doubles as seat rail mount) and a rear hole for the seat rail Both sides, with temporary bolts
Post by casesensitive on Jan 12, 2014 23:48:51 GMT
If they don't look straight, it's because the seats weren't! I bought 'em off Fleabay, and I'd say I spent at least 4 hours compensating for the fact that the embedded female M8 'nuts' in the seats were wonky.
Post by Paul (madeye) on Jan 13, 2014 8:51:56 GMT
what have you got between the spacers and the seat? those will punch straight through the fibreglass after a couple of times sitting down. you will need something substantial to spread the load.
Post by casesensitive on Jan 13, 2014 9:52:08 GMT
what have you got between the spacers and the seat? those will punch straight through the fibreglass after a couple of times sitting down. you will need something substantial to spread the load. Hmmm, nothing as yet.. The seats have 4 captive M8 nuts built into the base. the spacers are 12mm wide at the top, but I take your point, I should probably stick a washer or load plate in at the top.
Post by casesensitive on Jan 13, 2014 22:58:43 GMT
Post by Paul (madeye) on Jan 14, 2014 7:15:52 GMT
mate, ive only just gotten the floor on after 18
Post by casesensitive on Jan 22, 2014 13:30:38 GMT
Mounting the seats more permanentlyIn order that I don't tear apart the cross-beams when I brake, I've reused some integral-washer nuts (M8) I lifted from the donor. They'll sit outside the floor. Hoping to pick up some 1mm rubber sheeting to cover the entire underside, but postage is more than the rubber (£27 v £22 for 3mx1.2m)! In addition to the 4 M8 bolts, I stuck 8 welds on each seat, and rounded down the rectangular bar to make it fit in a little better with its cylindrical neighbours. Heated the pieces up first, because the welder I've borrowed is puny (100A) and the mild steel bar is 8mm. Won't win any awards, but I'm happy with it for now. 4 Sundays just extending my seat rails, this might take till I'm 40!
Post by casesensitive on Jan 22, 2014 13:38:33 GMT
Post by casesensitive on Feb 16, 2014 21:34:24 GMT
Wrapping the floorVinyl, seems like a great idea, but a bot of a hoor to work with. No matter how many times I pulled it up and heated it, I couldn't get the wrinkles out. Any kind of excess bunches up badly, doubt I could make it go around the cycle wings. Definitely not vinyl-wrapping the body panels now! SIlver lining though, the worst parts will be under the tubular sections and beneath the fuel tank.
Post by airforceone on Feb 16, 2014 22:49:09 GMT
If that's Matt Black wrap then that's the problem.
The carbon stuff covers any imperfections due to the carbon effect, the Matt colours will show any creases at all, and the colour always seems to disappear and leave a white line/crack effect.
I never had any massive issues with mine but would never consider any complex shapes like the wings or engine cover. Doing the tunnel in one piece nearly had me in tears on several occasions much to my wife's amusement.
I also been told that a good quality marine paint and a spray gun can provide good results..
Post by casesensitive on Feb 17, 2014 8:45:36 GMT
Yeah, the moment I unrolled it I got the feeling I was in for a few hours frustrating work. It is matt black, and I chose quite a thick vinyl so it wouldn't rip too readily. It did tear in two places as I was working it, but a small patch underneath did the trick.
The stuff has air holes, so you can work out bubbles, but creases you're stuck with once they form.
Still thinking of trying plastidip for the underside; once I have all my rivets in, might see if I can chuck it up on a lift and spray the underside. I went out for a go in RTR's Race Rocket, and while it was great craic, the sound of sound chips striking the underbody was disconcerting, Wifey would get in once and never again! Rubber matting is an option, but if you could spray it on, might be worth a look. And if it doesn't work, no one can see it :-)
Post by airforceone on Feb 17, 2014 9:15:52 GMT
