Post by Froggy on Apr 27, 2013 19:29:24 GMT
Paul, im absolutely loving the starter and alt! Got me wanting to spend loads of money that i dont have! lol. see ya soon matey.
Post by Paul (madeye) on Apr 27, 2013 20:16:35 GMT
I'll post the pic of the banjo set up and the brakes later on
Post by kiwicanfly on Apr 27, 2013 22:41:15 GMT
What did you do about flares on your 45 deg alloy pipe?
To get round the perpendicular chassis member problem I was thinking about making a 90 deg but incorporating two 45 deg sections - horizontal / 45 deg / 45 deg / vertical. (Got to use the mandrel bender for something)
Cant figure out how to flare it though as the flaring machine only accepts straight lengths.
As you have now set the new standard on what pipes flares should look like the bar has moved higher.
Post by Paul (madeye) on Apr 28, 2013 9:21:54 GMT
ok it took a while to find them, but i think the end result was worth it, also the extra expense. i wouldnt have been happy with straight items. yes i know it needs some more T clamps on it
Post by airforceone on Apr 28, 2013 10:49:04 GMT
Just a quick on Paul.
The brake res is gravity feed to the master cylinders, will having the hose vertical to the cylinders cause fluid supply problems. I know a vacuum is caused by pushing the pedal but will it be enough to suck the fluid from the res.
I have the feed running down parallel to the cylinder inlet.
Ned
Post by Paul (madeye) on Apr 28, 2013 11:28:07 GMT
Once the air locks are out of the pipe it will be fine, the amount of fluid used from the res. Is minimal as the pads wear. Like syphoning, once its going, as long as the release end is lower than the feed gravity will sort it out.
Cheers though mate, its good to see that people are concerned and will ask about an idea.
Paul
Post by Deleted on Apr 28, 2013 12:29:18 GMT
Suppose cracking the banjos off to bleed air out the pipe before bleeding will ensure fluid at the cylinders;)
Looking good fella;)
Post by Paul (madeye) on May 4, 2013 8:06:16 GMT
Post by Paul (madeye) on May 4, 2013 19:02:13 GMT
well, after a completely wasted day in both time and fuel money, i thought i would waste some more. full roll of CF, debating on doing the kitchen floor in it. another steering cover made today for IVA purposes obviously. lets see how well the release agent worked.
Post by Deleted on May 4, 2013 23:48:34 GMT
As a little side note, IVA rules seem to show the drawing of exposed front wishbones, and everything within that area is exempt. Have a look and see what your interpretation is
Post by Paul (madeye) on May 7, 2013 7:44:59 GMT
i need to download the up to date version, i printed off last june i think
Post by Paul (madeye) on May 9, 2013 12:29:51 GMT
just collected my custom battery tray to fit next to the front left wheel mounts. im happy with it..
Post by Paul (madeye) on May 9, 2013 12:33:31 GMT
Post by Paul (madeye) on May 13, 2013 6:40:57 GMT
i clamped up all the coolant on saturday. ready to run some fluid mow to test for low pressure leakage. Thanks to scott, he pointed me in a direction for a handbrake mechanism. its tiny and gives 25-30mm of travel, i just need to fab. a substantial beefy bracket. but it liiks like mt brake can go in the middle again. sorry forgot to take pics.
Post by deanohonda on May 13, 2013 7:09:54 GMT
looking good dude was good to meet up yesterday & bounce ideas off each other :-)
