Post by Paul (madeye) on Mar 28, 2013 22:46:54 GMT
my massive problem is 7/16 8mm tailed banjos with a 45 angle.. its no happening at all.
got some excess samco angles and a 3m accelerator cable going up in the sales section too..
Post by kiwicanfly on Mar 29, 2013 2:22:32 GMT
You've got room for a spare wheel in the front mate with that radiator. or are you going to take my advice and put the snow shovel and chains in there Looking like good progress is being made. Why did you not go for a couple of 45 silicons rather than using the alloy 45? Any chance of a picture from the front showing the seat relative to the centre line? Are you going to coat or wrap your alloy panels or leave them plain?
Post by Paul (madeye) on Mar 29, 2013 8:19:15 GMT
Still got the battery to get in there today and debating on forming a platform to mount the ecu. But im unsure about having those cable lengths. If I used both silicone 45's the jointing distances wouldn't have worked properly. Panels are being left for now as there is work to be done after iva. I will then powder them black once everything is how it really needs to be
Post by Froggy on Mar 29, 2013 9:14:21 GMT
Looks awesome paul, good tidy work there.-dont expect anything less though from you!lol. Looking forward to seeing it in the flesh soon. Is that 45 angle on the chassis rail to support the engine cover? good idea if it is mate. chat soon no doubt. Wayne.
Post by Deleted on Mar 29, 2013 9:25:41 GMT
Liking it so far bud.. Don't forget the coolant inlet from the expansion tank;)
We have a good weekend for tinkering, and I appear to be banned from the garage. Noooooo!
Post by Paul (madeye) on Mar 29, 2013 11:18:35 GMT
Old skool (do you like how i wrote it all gangsta) rad meant I could do away with a large res/expansion tank and just have a smallish pot. Possibly just use another of the bullet oil breathed bottles.
Wayne, do you mean the 90 angle around the edge? If so yes its so I don't have to drill into it and its a solid seat for the iva cover as mine will also be scooping air in
Black braids for brakes and clutch ordered. Very good price too
Post by Deleted on Mar 29, 2013 11:45:03 GMT
Yes, you could do that, although if the filler neck for the rad, is lower than the cylinder head, you will have a bleeding issue. The small bullet breather thingy should give the air somewhere to go, but it would be nice to fill it from there.
Have u seem those expansion tanks with pressure caps? They are Coolant swirl pots. One of those would suffice.
Post by Froggy on Mar 29, 2013 13:51:15 GMT
Paul, yes thats what im on about, good idea that is, how does it stay in place though?
Just sent you an email by the way too.
How'd you get on with the brake pipes then? (price wise)
Cheers, wayne.
Post by Paul (madeye) on Mar 29, 2013 15:19:42 GMT
i have bought some rubber toggles, but switching to springs i think. wont know about discount till it comes to paying up buddy.
steve it was meant to say billet bottles, i got the cheap toyosport one
Post by Paul (madeye) on Mar 29, 2013 15:40:30 GMT
made a cardboard template, then marked out a piece of 2mm to try fab a battery tray. ill continue making it but already decided i want it to be even more complex i should say that its to locate next to the LH lower suspension wishbone, all will become clear soon
Post by Paul (madeye) on Mar 29, 2013 16:03:48 GMT
does anyone else think CBS is utter crap, not just for overpricing, but crap stuff and not stuff needed if your thinking of doing things outside the box a little.. (we dont like change)
Post by Deleted on Mar 29, 2013 16:38:53 GMT
Yes.. Expensive, and not great quality.
Post by Paul (madeye) on Apr 3, 2013 12:43:50 GMT
Post by Deleted on Apr 3, 2013 12:50:36 GMT
It should a least provide a quick modular wiring solution Just need the rolls of cable now lol...
Post by airforceone on Apr 3, 2013 12:53:38 GMT
I thought about buying that, decided not to as I hate Buying anything that has a crap picture and very little Description.
How does it look in the flesh Paul.
Is it actually worth buying, it would make things a lot Neater under the bonnet.
Ned
