Post by Paul (madeye) on Jan 3, 2013 8:53:53 GMT
ok had a littlle proress, problems so far, getting my rear hubs back.. now done and vapour blasted, getting RTR to reply to me about the lock nuts (its now 2 weeks later). and finding the correct track rod ends to fit the RD uprights/sierra rack. i got escort ones and the thread is a fine not corse. oh and my steering rod turning eccentrically. a few pics.. all shiny ;D im just waiting for my + 10mm wheel studs to come now to press in. thats another stalling point. hope they arrive today
Post by Paul (madeye) on Jan 3, 2013 20:20:58 GMT
Post by Paul (madeye) on Jan 3, 2013 20:23:17 GMT
Post by Deleted on Jan 3, 2013 22:07:37 GMT
Mate.....it has been the same for all of us!
A rubber mallet will be your friend!
Post by Paul (madeye) on Jan 3, 2013 23:09:05 GMT
Should I have to use the mallet though buddy, there is minimal freedom of movement in the suspension. And nothing should be hindering compression or rebound. It was about half inch mark. I had to wind the adjustment in about 4 turns to bring at closer, then force the rest, im hoping it will begin to free up once rolling and i keep bouncing on it
Post by Deleted on Jan 3, 2013 23:19:09 GMT
Same with mine, although when I removed the rear upright to fit the driveshaft, it lined up a treat. It's like it beds in, and provides a little pressure in the links.
Its strange that its never been corrected on the jig, it looks like an intentional measurement.
Can RTR shed any light on it?
Post by Paul (madeye) on Jan 4, 2013 0:02:46 GMT
That's what I hoped, that a few weeks being moved and compressed might bed it in. When its a little free-er, I can then start measuring sag and angles etc.
Post by Deleted on Jan 4, 2013 6:27:44 GMT
As everyone seems to have the same issue I can only assume that it is intentional. It would just be nice if we were made aware so we didn't think something was wrong!
Sent from my GT-I9300 using proboards
Post by bossman on Jan 4, 2013 10:51:49 GMT
Hi Paul. Sounds a bit frustrating for you at the moment If your needing any (in situ) viewing my garage is always open, noticed your question on Jacks build regarding front wheel bearing torque setting, the advice i got when i recently replaced my front bearings were tighten them until they feel right, because the split pin hole is well back on the shaft mine had been fitted with a series of washers and a sleeve made from tubing to bring the nut back up against the split pin, it just didn't look a proper job so iv,e replaced all that with a nyloc nut, then i dropped the pads out and took up play until there's no rocking on wheel and it spins freely, if you decide to go down that route the nut is a unf and i got mine from ripon farm services. regards John
Post by BobN on Jan 4, 2013 11:15:38 GMT
Looks like you had made good progress over xmas Paul. The build is looking good and so is that colour.
Post by Paul (madeye) on Jan 4, 2013 12:11:01 GMT
Few brackets and steering for to remake today.. And get tires, was gonna put part worns on the rear for rolling road, but not too keen on the to yo, going Yoko spec 2 I think
Post by Deleted on Jan 4, 2013 12:16:53 GMT
Are you throwing some Parada's on it?
Post by Paul (madeye) on Jan 4, 2013 14:11:40 GMT
Yeah mate. Any thoughts
Post by Deleted on Jan 4, 2013 17:16:31 GMT
I'm partial to R888 but the cost is extortionate. The Parada I found awesome, I had them on my evo4, I found on hard driving very sticky and soft, and if my cars tyres were squealing during a corner, then the guy up I disagree in the car behind was in deep trouble.
Claimed two like that, they dismounted the road trying to corner like a parada equipped Evo lol.
They don't have a long life, useless in slippy conditions, for road - awesome For track, you'll kill them in an afternoon, they tend to bobble ofer to the sidewall.
R888 are useless on the road when wet and cold, but dry.. Oh yes.
Federal do a R888 style tyre, and feedback is good, and half the price of r888's
They would be my bet. Try camskill for a price, they're not too bad.
Post by Paul (madeye) on Jan 9, 2013 8:14:46 GMT
Collected the head last night, 3 angles have been cut on the valve seats, all pressure and vac tested. Will start building that on friday hopefully.
