Post by r16 on Mar 28, 2010 20:58:38 GMT
mate thats amazing :-) the detail and quality is tip top! big thumbs up buddy :-)
Post by Scott on Apr 3, 2010 18:26:58 GMT
Cheers Phil, Few more bits done today , still plenty to finish off though, but it eventually got to see some light today ;D ;D ;D And a blip up the road ;D ;D ;D
Post by Andy on Apr 3, 2010 19:28:17 GMT
That is looking good Scott I like lego
Post by tr1kerfozzy on Apr 4, 2010 8:53:23 GMT
like the twin headlamps, are they the same as the atomic?
Post by Scott on Apr 4, 2010 9:46:50 GMT
Similar,,
But not confirmed yet,, trial fit only,,,,
Scott
Post by Andy Patey on Apr 4, 2010 19:57:54 GMT
Hi mate yes thanks for that, looks like you have been busy, yours is looking good too. Andy
Post by 2jags on Apr 7, 2010 21:21:23 GMT
hi scott the new build is looking excellent how did it feel on the run round the streets is the 1.8 got much more power the seats go well will it be at stoneleigh john mandy
Post by Scott on Apr 8, 2010 11:49:19 GMT
Hi John,
Cheers, getting there slowly, seem to go well but only went up and down the road to check speedo,,
Hopefully will get to show, car prob on trailer,,,
Are you bring your Rocket down to the show???
Scott
Post by 2jags on Apr 8, 2010 20:45:29 GMT
not sure i would have to trailer is think to far incase weather changes when is the dates forgot when i eas down will have to make an effort to see new build john mandy
Post by Scott on Apr 9, 2010 19:14:04 GMT
Come on John, You can drive it down,,, put your rain coat on you will be fine,,,
May 2nd @ 3rd i believe,
Would love to see the old car again,,
mark
Junior
Post by mark on Apr 24, 2010 19:01:12 GMT
Hi Scott decided to rip off your design for the exhaust. Bought a universal silencer with twin outlet. Only just fits between drive shaft bearing carrier and the rear tubes on the chassis. I see how you blanked off the twin pipes but when you drilled through the side how did you fit the tube into the internal Y piece? what size pipe did you use for the inlet and how did you decide on the bend angle? cheers mate.
Post by Scott on Apr 24, 2010 19:16:04 GMT
Hi Mark, You have taken on a right job there, I put large hole saw bit straight through the side and Y section, Which was stainless and knackered a couple of bits and then had to be finished with plasma cutter took 4" section from doner pipe with the bolt flange and die grinded hole until that fitted nicely into the Y section,,, cut through 90 % of pipe and bent to get correct angle, then cut a collar from another bit of the doner pipe and grafted over the cut and welded up, and then welded it into Y section through the tail pipe holes, before welding them up, bit of a pain, but worth it, sounds the B******s not easy to explain but give me a ring if you need to,,, Scott
Post by Scott on May 7, 2010 21:18:40 GMT
Post by nigel on May 8, 2010 8:18:45 GMT
Absolutely Beautiful Scott "Legendary" Your builds set a benchmark for use all to try and aspire too. nigel
Post by 2jags on May 8, 2010 19:12:01 GMT
hi scott you got some good shots first class did you grt any intrest on the monday john mandy
