Post by stevieboy on Jun 8, 2012 7:54:47 GMT
The seats weigh 118kg each. steve
Post by welshy1 on Jun 8, 2012 9:41:38 GMT
The seats weigh 118kg each. steve God they are heavy aren't they. Do you mean 1.18kg each not 118kg. ;D
Post by stevieboy on Jun 8, 2012 11:26:48 GMT
Ha Ha well spotted , must have been sitting in it at same time, just to confirm, 11.8 kg each
Post by h5ngs on Jun 8, 2012 14:09:29 GMT
That seems pretty heavy still or is that including the mx5 runners as well? I'll measure the weight of a standard mx5 cloth seat and leather seat tonight and put it up to show the difference
Post by red5 on Jun 8, 2012 19:48:55 GMT
All looking good steve
Sorry to here about the accident - i split my helmet once......and on a hole ;D
Post by h5ngs on Jun 10, 2012 12:23:44 GMT
Measured the seats by weighing myself and then reweighing holding the seats. Ive worked it out as the following:
standard fabric seats with separate headrests and seat runners - 15.9kg
leather seats with separate headrests and seat runners - 14.7kg
As stevieboy said the fibreglass seats weigh - 11.8kg
So thats saves 8.2Kg for both seats over standard which is quite a lot of a saving.
Post by h5ngs on Jun 12, 2012 21:17:38 GMT
My seats arrived today so weighed them and double checked the original seats, this time by placing the seats directly onto the scales. I weigh them at
fabric - 13kg leather - 12.7kg and the new plastic seats only came in at 5.5kg however this is without the mazda runners which will probably be quite heavy.
Post by stevieboy on Jun 13, 2012 20:14:51 GMT
Did you get them from the birmingham source, or are they different ones to mine. Steve
Post by h5ngs on Jun 13, 2012 20:51:29 GMT
They are identical to yours, yes got them from a guy called marc from the link you gave.
Post by stevieboy on Jun 13, 2012 21:23:56 GMT
Nice one, glad to be of assistance, original runners fit just nice, need about six washers under the seat though. Steve
Post by stevieboy on Jun 14, 2012 21:09:16 GMT
Being still laid up with a broken collar bone i'm looking at doing a few easy jobs for the weekend. First is one already mentioned by others but i still cannot find mine....1.8 engine number... my logbook has the engine number the same as the chassis number, it is an import and i'm worried that this was made up for the import, help please. Next do i need seatbelt warning and handbrake warning lights. Might be able to those things without to much pain, no Newark for me this year Steve
Post by h5ngs on Jun 14, 2012 21:55:48 GMT
I would say yes to the handbrake warning and no to the seatbelt warning light. As some people use harnesses and have no issues,
Post by Deleted on Jun 15, 2012 8:04:11 GMT
Pretty sure my import didn't have an engine number. There's a big bar that sticks out from the rear corner of the engine block. It's usually stamped on there. First build didn't have one. Was an issue for the IVA test, but he seemed to over look it on the retest. My advice would be to buy a cheap punch kit and add it yourself while it's early days!
Post by stevieboy on Jun 15, 2012 17:54:13 GMT
Thanks guys for the info, lets hope the rain stops so i can get something done. Steve
russ
Junior
Post by russ on Jun 17, 2012 8:44:00 GMT
Hey Stevieboy, had the same issue finding the engine number on my 1.8 import, found it by accident when cleaning, it is stamped on the block under the coil pack (next to the cam sensor), it's no wonder most imports have the chasis number or like mine no engine number at all. You can either send off your V5C and have it added (best as then there are no questions) or try and blag it through but then you may have issues confirming what year the engine is and therefore what emission test is required. Hope this helps.
