Post by dinosaurjuice on Nov 25, 2009 21:08:12 GMT
Carrying on from my 'hindsight' thread, ive started hacking apart the rocket to make some modifications. the entire floor is covered in a thin film of diesel. horrible dirty fuel been busy drilling out rivets and welding up the holes. when will the fun stop First glance would suggest theres enough meat on the top wishbones to mill out and fit camber sleeves - ill post some pics when this is done. will
Post by r16 on Nov 26, 2009 17:22:11 GMT
nice one will, let us know how the fitting of the camber adjusters goes! that is a big engine mate :-)
Post by dinosaurjuice on Nov 28, 2009 20:14:52 GMT
took the engine out yesturday. i had forgot just how tight the fit was. a good half hour of wiggling before it was free the beast in all its glory. this is going to take some cleaning/painting. have since seperated it from the gearbox, just to make moving it around easier. the gearbox is a back breaker in itself... next job? weld in the new engine mounts Will
Post by brownie on Nov 28, 2009 21:01:50 GMT
Wow thats a big gearbox dude, what is it ?
Post by dinosaurjuice on Nov 28, 2009 21:16:11 GMT
Wow thats a big gearbox dude, what is it ? its a 'MMT6'. also used on the 3.0 st220 apparently
Post by Scott on Nov 28, 2009 22:12:20 GMT
Is that from a Tractor
Post by nigel on Nov 29, 2009 10:25:22 GMT
Great to see you getting stuck in 'will' ;D I'm looking forward to the all new 'smoking rocket' next year nigel
Post by Andy Patey on Jan 2, 2010 19:57:55 GMT
Hi Will, I'm having trouble putting pictures on this site. I lost your number when my phone went wrong, could you email me your number so that I can call you and let you know whats happening, basically when I put pictures on they tend to go side by side and then mix, not sure what we are doing wrong Email is Abpatey1@aol.com. Thanks. Andy P
Post by JimmyZ on Jan 2, 2010 21:21:47 GMT
Andy, Sending you a PM Hope that helps
Post by dinosaurjuice on Jan 8, 2010 16:50:57 GMT
moved back up to lancaster now, so time for an update! 2 top intercooler mounts made from 38mm angle: and a single lower support from 32mm flat: i think it looks a beast: Will
Post by r16 on Jan 8, 2010 17:14:06 GMT
nice one bud i like that :-)
Post by dinosaurjuice on Jan 8, 2010 17:35:44 GMT
ive had to raise the OS engine mount to prevent the sump hitting the chassis (a previous problem), but had to notch out a rollbar stay in order to do so. im undecided as to whether it needs an extra support or not... will
Post by Andy on Jan 9, 2010 9:49:43 GMT
Hi will nice cooler mate not sure if you would need to support any more and how you could add any ask the stig . Lego
Post by JimmyZ on Jan 9, 2010 9:55:19 GMT
That looks pretty wicked
Post by dinosaurjuice on Jan 9, 2010 18:00:53 GMT
Hi will nice cooler mate not sure if you would need to support any more and how you could add any ask the stig . Lego had a good look at it today, and ive decided to leave it as is. the tube is nearly 3mm thick, and the curved plate ive welded in is 2.5mm. if i was using the car for trackdays and racing i would definately brace it, but in my opinion its plenty strong enough should i roll it at road speeds. still, i shall phone stiggy monday to ask his thoughts. progress: none today, apart from a few more sockets in the garage. can never have too many! Will
