Post by carlyd on Oct 30, 2023 12:28:17 GMT
Hey guys, me again. A fews years ago (2013 - 2016) I built an original Mev Rocket with a Honda Accord Type R Engine (see my other build diary).
Well here I go again, this time a Rocket 2 which I just purchased from a guy in Norfolk.
I will document the stripdown and rebuild and as Rocket 2 is basically an original Rocket with a different bonnet I'm not expecting too many surprises. Famous last words
The History of this car
This Rocket 2 was originally purchased by a guy in Scotland (anyone know who this is?) who got it to the rolling Chassis stage and then sold it on to the guy who I purchased it from. The chassis is approx 5 years old and is grey with Black GRP Bonnet and Cycle wings.
I bought it as a car with no engine and no IVA, however it previously had an ST170 engine and gearbox and had been sent to Exo / SVE for IVA prep and was all ready for IVA but apparently blew the engine before the test. The owner removed the engine and is trying to return it to the person he bougt it from.
The owner then advertised it on Ebay at a starting price of £7k and had no bids, so I made a low offer and bought it.
Current Condition
It's very obviously been sat outside for a period of time in the rain as suspension arms are very rusty, as are some bolts etc so it's rough.
I received lots of parts with the kit, exhaust, ford gearbox, seat belts etc so it's basically a full kit minus the engine.
My Plan
I was planning on building a buggy type car of my own design so bought a Honda Accord Type S a few years ago as a donor. This has the K24A2 engine and 6 speed gearbox and the car drove like new when I bought it. I stripped it and have already reconditioned the engine and parts ready for a new build. So now I have a Rocket 2 that is looking old and rusty and a virtually new engine, so.... I am going to implant the Honda K24 into the Rocket 2, and from my research it's not been done before in a Rocket 2. The K24 should be good for 190bhp as standard and it's the same engine you will find in the Ariel Atom and Nomad.
So my basic plan is to do a complete strip down, then rebuild with the Honda engine and gearbox, fit electrics, cooling and basically rebuild the car to a high standard. Then do another full strip down, new powder coat (not sure on colour yet) and then final reassemble.
Stage 1
Strip it back to a rolling chassis to give me good access to the engine bay so I can test fit the engine and gearbox. I will need to manufacture new engine and gearbox mounts. Once this stage is completed I will leave the engine in place so I can plan where to put ECU, route wiring and all engine ancillaries.
Stage 2
I hate P clips and bolt on brackets so I am going to weld tabs etc to the chassis so these are permenant fixtures, this will be done as I am rebuilding the car to a high standard, using new bolts and quality parts.
Stage 3
A full strip down to bare chassis. Unfortunately the floor was pop riveted on (my last build I used rivnuts for this exact reason). I will need to drill out approx 300 rivets to remove the floor which leaves me with the issue of 300 rivets floating around inside the chassis. I know I could use wax oil or something else to spray inside the chassis to stop the rattle but as this is going to be a high quality build my plan then is to cut off the circular blanking plate at the very front of each lower chassis member and simply tilt the chassis to empty the rivets out. I will then weld the plate back in. When I refit the floor (during reasemble) I will rivnut it back on.
Stage 4
Powder coat chassis, suspension arms & various parts
Stage 5
Reassemble.
Stage 6
IVA and Register
Stage 7
Track days, driving it like I stole it, which I did
I will add some photos now, and as I progress I'll add more.
Some ideas I am having
Fuel tank, I don't like this, I may manufacture a larger tank to run behind both seats (usnure just yet)
Roll cage ?
Second skin of the floor in front of driver and passenger seat (to sit on top of chassis) as I am always worried of pushing the floor off when standing on it.
Having Battery in the front next to the radiator to help with weight distribution.
Hinging the bonnet (currently have to unbolt it).
LCD full colour Dash (any suggestions)
Wider seats as I can't get I I disagree in these. They also pinch my back as I have a wide back (apparently) so any suggestions on wider seats would be appreciated. These are 360mm at the ass, I need 400mm I'm guessing
I have lot's of parts with this kit that I won't be using so this stuff is for sale if anyone is interested.
x2 GRP fireglass seats (too narrow for my fat ass)
x2 Blue TRS 4 point hardness new never fitted)
Koso Dash (RX2N)
Ford gearbox (not sure which model)
Ford Oil Catch can
Please message me if you are interested in any parts.
Current Condition
My Plan
Stage 1
Stage 2
Stage 3
Stage 4
Stage 5
Reassemble.
Stage 6
IVA and Register
Stage 7
Roll cage ?
Koso Dash (RX2N)
Ford Oil Catch can
