Post by rv8air on Jul 20, 2020 15:18:24 GMT
Kit arrived on July 19, and the donor had already been stripped down to the PPF, so we're ready to begin the assembly. My kit came powdercoated with welded floors. First step is to attach front and rear bulkheads, which I'm going to rivnut into place. It's more work in the beginning, but the fact that I can take it apart if I need to, appeals to me. I've already observed that the bulkheads don't all fit flush to the frame, which means some trimming is in my future, right off the bat. Curious if anyone can suggest an efficient method to trim the bulkheads? I've got snips and grinders and saws, which means I could jump in and thrash about until something looks about right, but I'd sure like to do it well. Any suggestions?
russhowell
Post by russhowell on Jul 21, 2020 6:50:16 GMT
Hi, I just used a jigsaw which gave good clean cuts. Obviously cardboard templates first. In my experience the bulkheads are the few sections that probably would not need easy removal in the future. However the tunnel will benefit from rivnuts.
Also, it became apparent that if you can stop any squeaks and rattles it will be a more pleasurable machine, so rivets were widely used. Good luck, Russ
Post by rv8air on Jul 21, 2020 17:21:19 GMT
Thanks Russ. I've got the bulkheads sorted, using a 3 inch cutoff wheel, cleaning them up with a file. Moving on to the pedals now. The bend in the gas pedal is my next step, and I'm over-thinking the problem, as usual. I guess I'll just vise it up, heat it up, and pound on it until I like it Also the bracket for the clutch pedal standoff doesn't align with the pedal's bracket - the two holes are offset by half an inch. These are not a big problems, but that's all part of the fun!
Post by rv8air on Jul 23, 2020 18:59:32 GMT
BTW, I decided to blind rivet the bulkheads in, but as Russ suggests, I'll use rivnuts on the trans cover. It just sounds more sensible. So many folks have shared so many photos of their builds, adding a photo of mine is awfully redundant. However, after waiting and preparing for the build to finally start, hitting a milestone should be shared. So, here's DaBeast, on it's own feet after the frame bolts are aligned with the chassis, and the coilovers installed. Tomorrow morning when it's cool, I'll get under her to apply threadlock and torque the frame bolts.
Post by rv8air on Jul 24, 2020 17:54:10 GMT
Well, the chassis is secure to the subframe now, and the steering column is installed. I had a start, not knowing there was a supplied bracket to mate the column to the chassis. After consulting the build guide, and telescoping the column out one inch, it went together easily. I am impressed with the ease of assembly, so far, as I've been able to do it all, singlehandedly. Even dropping the chassis on went well, using a shop crane to lift, and dollies under each tire.
Next step is the radiator. I understand NBs require special bracketry...
Post by rv8air on Jul 26, 2020 0:40:17 GMT
Moving on to the next thing, I've acquired a radiator from an NA, and after a couple of hiccups, have installed the bracketry to mount it. Fans and hoses are still off. It looks good in there. BTW, my NB donor came with an aftermarket radiator which is different from the NA style, in that there's two smallish hoses at the bottom. What are these for, and do I need them?
Post by snowbird1 on Jul 26, 2020 14:22:18 GMT
The two smaller connections are probably for an automatic transmission cooler, you can leave them open or cap them off. The good news is that it should be a higher capacity radiator, I think about a third more than the standard radiator.
Post by rv8air on Aug 2, 2020 14:53:42 GMT
Post by rv8air on Aug 7, 2020 19:25:58 GMT
Not really much to report, although it was kind of exciting for me. Ground connections were made, two at the front and two at the rear for the chassis loom. The engine/trans was grounded to the chassis at the firewall. The battery was grounded to the chassis as well and to the PPF. Grounds in seven places, total. Just for giggles, since I alread had the wiring loom laid out and connected to most things, I connected the battery and gave the key a twist as I push the clutch lockout in with my other hand. The dash came to life, and to my great relief, the starter turned the engine over. Of course it wont run without fuel, and the ECU's not connected, but it was encouraging to get to this point. Exomotives braided lines arrived today, for the clutch, fuel, and brakes. I spent the extra bucks to get them preformed to size, so installation will be a snap. After my siesta, I'll get the fuel lines connected, and plug in the ECU, maybe she'll actually run!!!
Post by rv8air on Aug 8, 2020 1:38:36 GMT
The connection of the braided line to the fuel rail was not as easy as I'd hoped. There's some disassembly at the intake manifold to get access to the fuel rail, and then some cursing to get the old line off the inlet pipe. I'm much better, now.
Post by kev80 on Aug 14, 2020 8:58:09 GMT
Sounds like you are making swift progress! Looking forward to more updates.
Post by rv8air on Aug 14, 2020 18:24:48 GMT
Very little progress since my last. The exomotive braided brake lines went in well. The fuel line had a pretty good bend in it, at the fuel rail, so I installed an -6 AN ell in there to make things less tense. I'd left the knock sensor connector hanging when iI put it back together, so there was an adventure to resolve that issue. And then, I snapped off the brake bleeder valve at the right front, so there was a trip to the salvage yard for that. One stock seat's been installed, for my lovely and talented assistant brake bleeder to sit it while she pumps the pedals for me. That will come later. Right now, I'm trying to figure why it won't run. It cranks and the dash lights up, but there's little else going on. The fuel pump will run when jumpered, and the plugs fire when the air intake is primed with starting fluid, so the problem seems to rest with the main relay not getting a signal to open. Laissez les bon temps rouler!
Post by rv8air on Aug 15, 2020 17:11:14 GMT
Main relay ground had been lost. The PO had rerouted it, and during demo, the connection to its new ground spot was lost. Once reconnected to its original orientation, the main relay closes with the key switch, and the fuel pump will pump if jump to ground. As stated previously, the car already cranks, and sparks will fire on starting fluid, so we know the ignition circuit is good. Now I need to know what the ECU needs to see before it allows the car to run...
Post by kev80 on Aug 15, 2020 22:17:54 GMT
It's not immobilizer related is it? Never sure with Japanese cars, but some UK cars only cut the fuel pump on the immobilizer, ignition and starter work as normal. Longshot, but an idea.
Post by rv8air on Aug 19, 2020 18:40:19 GMT
It's ALIVE! The big connectors were mismatched - once I connected white to white, black to black, and blue to blue, she fired right up. The data link readout now tells its secrets from the data link, and all seems in order. Brakes and clutch are bled and firm now, and it runs. All that's left is everything else, eh?
What a stupid error, huh? I spent easily three days chasing grounds and looking for lost connectors only to find I'd swapped those big connectors around in my haste to assemble the loom. I had relied on a blog statement that claimed all connectors are unique, and there's only one way to reassemble it. Well that's true, but ya gotta pay attention to colors too.
Sometimes I wonder how I manage to get myself dressed...🤨
