Post by flynn on Jan 13, 2011 20:37:43 GMT
mightylad
.....Mighty MEV Rocket.....
Post by mightylad on Jan 14, 2011 21:39:31 GMT
looking good buddy!!! i like the idea of the drill attachment - nice video!
Post by leicesterkev on Jan 22, 2011 10:19:46 GMT
Hi Flynn,
Hope the build is going well! I'm trying to get a few bits and pieces before I pick up the rocket kit next weekend (hopefully) but am struggling to find somewhere that sells the right size button head bolts for the suspension and steering rack...... any suggestions would be gratefully received....
Kevin
Post by andybaird on Jan 22, 2011 11:08:37 GMT
Hi Kevin I'm building a sonic 7 and got the button head bolts that I needed from: www.shop4fasteners.co.uk. They are reasonable priced and quick delivery. Cheers Andy
Post by autonut on Jan 22, 2011 11:13:58 GMT
I have just received my suspension bolts. They are M12 x 70 Socket button head bright zinc plated bolts and nuts /washers to match. I ordered them from www.fix8.co.ukI also separately ordered 4 M12 x 80 A2 stainless from ebay from www.boltmeup.co.uk
Post by leicesterkev on Jan 22, 2011 13:17:59 GMT
Cheers. Bolts ordered and on their way!
Thanks for your help
Kevin
Post by dj180 on Jan 23, 2011 12:20:29 GMT
Hi Flynn
Liking the pictures, I hope my garage looks like that in about 6 months, MEV Rocket beside the street triple.
Good look with the build.
All the Best
DJ
Post by flynn on Jan 23, 2011 15:06:26 GMT
I got my fixings local. I bought 40 M12 x 90mm which Ill cut down to suit. Also got the rest from the manaul 20 No. at 3mm x 12mm self tappers for the centre tunnel. 8 No. at 6mm x 25mm bolts for the rear cycle wing stays. 4 No. at 8mm x 100mm bolts for the front cycle wing stays. 4 No. at 8mm x 50mm with 12 nuts to mount the pedal assembly All in for £17 because there card machine wasnt working and thats all I had on me Hi Flynn Liking the pictures, I hope my garage looks like that in about 6 months, MEV Rocket beside the street triple. Good look with the build. All the Best DJ Cheers buddy. Its a Street Triple R by the way
Post by flynn on Feb 9, 2011 18:25:35 GMT
A little more progress today. Waiting for my brakes to come from RTR. Going for the Hi-Specs instead of the wilwoods, although looking unlikely that they'll be here for the weekend. Fitted the wishbones and suspension, need to trim down the bolts tomorrow. Cant wait to get it rolling Bought some alloys of ebay. TD Pro Race 1.2, with tyres. £200. Bargain!
Post by leicesterkev on Feb 10, 2011 12:09:20 GMT
Hi Flynn,
Love the wheels.......and the build looks great so far. Can I ask how you went about getting the crush tubes in the bushes? I've managed to get one in so far with an awful lot of hammering but it wasn't easy at all and I'm thinking that their must be an easier way.....
Kevin
Post by flynn on Feb 10, 2011 12:25:12 GMT
I ask about this in the technical section and got some good advice. I used a dremel and grinded the edges off one end on the crush tubes, so it has a beveled egde. Then lined it up and hit it with a rubber mallet. I found that the first hit only had to be a soft one to initially get it lined up in the bush, then gave it some hammer and finished it of in a vice. When I tried doing it without the beveled edge, it was a nightmare. Hope this helps www.mevowners.proboards.com/index.cgi?board=chassis&action=display&thread=950&page=1
Post by leicesterkev on Feb 12, 2011 19:47:25 GMT
Hi Flynn,
Many thanks for the tip! bevelling the edges made all the difference.....
Kevin
Post by flynn on Feb 12, 2011 21:20:17 GMT
Hi Flynn, Many thanks for the tip! bevelling the edges made all the difference..... Cheers Kevin Yippee Glad it helped. Exalt my karma Just bought a Wilwood pedal box of ebay. Need some track rod ends and going to order some wilwoods for the front. Was going to go for the Hi-Specs that RTR was going to supply, but I cant wait any longer. Need to get it on its wheels, so wilwoods it is May look to see if AP or Alcon do anything that will fit..... Rear hubs on there way, just need to decide what to do with the rear brakes. Standard focus rear or something else.
Post by flynn on Mar 14, 2011 22:15:04 GMT
Had the bearings pressed in today and picked up these seats on Sunday. Carbon Fibre and they were a steal. Need some TLC, but Ill get them looking all shiney and new. Slowly coming together
Post by flynn on Mar 26, 2011 14:28:35 GMT
