Post by p2tav on Aug 18, 2017 7:20:03 GMT
cheers gwnwar,
I will have a look at that today good idea:) as for the red white blue I thought I'd done that? is it not showing when you look at my posts ? I have put UK W/Y MEV EXORCET MX5 MK2.5 1.8S-VT ?
regards
Post by p2tav on Aug 18, 2017 14:53:24 GMT
Day 2, Done about 6hrs today got all wiring sorted and all out of the car. I have removed all parts not needed bumpers carpet etc. just got to the point on the build guide where it says drain fuel tank and hit a problem as my car does not seem to have a drain plug on the fuel tank . I will go on the tech section and ask a few questions as I'm at the point where a bit of advice would help. a couple of pics bellow to show you where I'm upto, on nights this weekend so probably wont get much done for a few days.
Post by miket on Aug 18, 2017 16:25:20 GMT
Rather than undoing an old drain plug for its first time and risk any damage trying too hard; just syphon it out? If you use the ploy of drowning a load of the end of the syphon tube to start with you don't even need to risk smelling / tasting / drinking it. Just a thought if it's slowing you down,
Post by gwnwar on Aug 18, 2017 17:54:21 GMT
If you don't have the right tool to release the fuel hoses get one.. They are cheap and make removing hoses 1,2,3 job.. You can remove the center most hose from the fuel pump plate (supply line)on tank, put on a hose and clamp to the plate, put 12V to the I believe R/L (L=blue) wire and ground to black from battery that will run the pump till tank empty.. Some tanks had a drain bottom left forward.. Before pulling the body remove front sway bars from body, steering shaft, E brake cables,brake hoses clutch hose or slave,push wires from battery through floor so they are free of body and clamps,ground below exhaust manifold to body, speedo cable clamped to body, harness to trans and O2rear sensor under left seat push through floor.. Iam sure I forgot some.. Have fun
Post by p2tav on Aug 18, 2017 18:04:36 GMT
nice one cheers
Post by p2tav on Aug 18, 2017 20:59:34 GMT
i have posted these questions on the tech section under help but they might fit better hear? so they are as follows,
my car has ABS and I would like to keep it if possible but with regards to the brake pipes under the bonnet do you try and save them or just chop and make new ones when I start the rebuild as I'm spending too much time trying to save things especially if you just make new ones ??
with regards to the radiator is it better to buy a mk1 as the Exocet is designed for it and if so does the fan from mk2.5 fit on mk1? or would I need to buy a fan as well?
cheers
Post by mikeeyboy on Aug 18, 2017 21:02:14 GMT
Most people make new brake lines, the original steel ones would be really hard work to make fit the exocet chassis.
If you are using the MeV bonnet bracket the mk1 radiator is better as the hose feeds are in a better position.
I ditched my mk2 rad and bought a mk1
Post by mikeeyboy on Aug 18, 2017 21:04:57 GMT
Forgot to add, the fan is also different, you would need a mk1 radiator and fan. Radiators are cheap on eBay and I picked a used fan up for about 20 quid
Post by p2tav on Aug 18, 2017 23:48:34 GMT
Thanks Mike,
did you keep the ABS on your car ?
Post by gwnwar on Aug 19, 2017 5:51:31 GMT
If you do keep the ABS take pics of were the tubes go to and draw a pic of it to.. There have been builders who kept the ABS. Haven't heard any bad about it.. If you drop it you will need a new brake master for non ABS..
Post by mikeeyboy on Aug 19, 2017 8:46:36 GMT
Thanks Mike, did you keep the ABS on your car ? No, I removed it. I wanted as simple a car as I could manage
Post by p2tav on Aug 19, 2017 20:21:07 GMT
Post by p2tav on Aug 20, 2017 19:05:04 GMT
Post by mikeeyboy on Aug 20, 2017 19:10:29 GMT
Your car looks in good nick. I know a good powder coaters just off junction 38 of the M1 who will blast and coat all the mx5 parts for a very reasonable price.
He's painted my chassis and one other exocet so far. Also can powder coat calipers.
I'm not sure whether 17's would fit under the wing mounts more than anything. Drop Stuart an email and he will confirm
Post by p2tav on Aug 20, 2017 21:05:48 GMT
cheers mikeeyboy, I'm having MEV do the chassis but might be good for the other bits so please drop me the name and number. As for the wheels i'm not sure what to do with them as they need refurbishing and i like to put new tires on them as i don't know the history of them so when you add up the costs say £200 for the refurb and £360 for 4 new tyres it might be better to get a wheel and tyre combo i'm being told you can get one for about £500 ? have you bought any spacers and if so what size do you need to get? cheers,
