Post by p2tav on Sept 1, 2017 14:05:33 GMT
Post by p2tav on Sept 1, 2017 15:32:29 GMT
can anyone show me some pictures of how much they cut the front upper wishbones for the plate to bolt onto them please?
Not sure if i cut the center piece right out or just enough for the new wishbone banana plates to be clear of obstruction?.
Post by gwnwar on Sept 2, 2017 4:21:37 GMT
A lot would depend on what shock setup you will be running..
Post by p2tav on Sept 2, 2017 6:50:17 GMT
hi gwnwar,
i have the original sport bilsteins that came with the car and a set of lowering springs that are 40mm lower than standard? cheers
ybot19
Junior
1990 eunos roadster
Post by ybot19 on Sept 2, 2017 8:30:57 GMT
Some standard shocks may fit the gap, but If they don't, cut away the central stem between the two holes that the bananas use to be bolted on to
Post by mikeeyboy on Sept 2, 2017 15:39:12 GMT
Just bolt the banana plate to the wishbone and draw round any material in the centre that sticks beyond it. This is your cut.
I used a reciprocating saw to trim the shape of the banana in to it.
Post by mikeeyboy on Sept 2, 2017 15:40:19 GMT
Also make sure you cut the lip off the front subframes whilst you can, take about 20mm off it, otherwise the shocks will hit there as well.
Post by gwnwar on Sept 2, 2017 17:16:24 GMT
I would fit the shocks you have, then see if you have to remove metal should not have to.
Post by mikeeyboy on Sept 3, 2017 0:07:49 GMT
I think MEV changed the angle of the shock mounting on the new chassis. All build threads from the last 18 months or so cannot get the chassis on without cutting the edge off the front subframes with at least the mk2 cars.
Post by p2tav on Sept 5, 2017 11:48:29 GMT
hi all, could do with a bit of info for forward planning (IVA in mind) 1, can you use braded hoses for iva ? 2, brake pipes 3/16 ? and what type of flare ? 3, can you use aftermarket steering wheel for iva or use original until pass ? what about air bags?? 4, if I use the seatbelts from my donor it has explosive pre tensioner on them can I still use or do I need to buy new seat belts? 5, with regards lights for iva what do they need to have on them i.e. E Mark or can I use any type ? what about LED lights do they need any marking on them cheers
Post by p2tav on Sept 5, 2017 14:43:34 GMT
wow just found out that having spent 4hrs pressing bushes out of bottom of bilstein sport shocks that are standard on my donor you cant get the replacement bushes as no one sell them !!!!!!!!! how bad is this does this mean I have to buy new shocks just because the bottom bushes were shot??? the outer size of the bush is, diameter =36.5mm x 45mm wide has anyone any ideas?
Post by moley on Sept 6, 2017 15:15:44 GMT
wow just found out that having spent 4hrs pressing bushes out of bottom of bilstein sport shocks that are standard on my donor you cant get the replacement bushes as no one sell them !!!!!!!!! how bad is this does this mean I have to buy new shocks just because the bottom bushes were shot??? the outer size of the bush is, diameter =36.5mm x 45mm wide has anyone any ideas? Would you not get poly bushes made up for this or possibly even get off the shelf ones?
Post by p2tav on Sept 6, 2017 19:43:18 GMT
i have looked at getting some off the shelf ones and they just don't do them not even Bilstein sell them As for getting them made no one is prepared to do a one off run of them as it costs too much. one of the members has found a company that has made some on Ebay and i have been speaking to them but they are designed to fit by leaving the old metal sleeves in situ (which i have removed) so going to order them at a cost of around £80 and fingers crossed they will fit. still cant believe that i cant get them off the shelf.
Post by gwnwar on Sept 7, 2017 20:57:19 GMT
Post by p2tav on Sept 8, 2017 6:35:58 GMT
Hello Mev owners,
Does anyone have any of answers to 5 my questions above ?
cheers
