Post by mawdo81 on Jan 23, 2016 11:23:38 GMT
Me too but getting the engine in position is taking longer than I want. It's supplies- I'm waiting on 4mm plate to make a transmission mount adapter. I've debated not waiting but then I won't know clearances as we've discussed ;-) plus the risk of moving the engine with the side and rear panels in position.
I'm targeting in position, if only resting, next weekend.
Post by p5curly on Jan 23, 2016 19:08:42 GMT
What size 4mm plate are you after
Post by mawdo81 on Jan 24, 2016 6:59:54 GMT
200 X 200 is on order.
Post by p5curly on Jan 24, 2016 11:47:56 GMT
Have you still got to shape it to fit
Post by mawdo81 on Jan 31, 2016 18:05:21 GMT
Pictures to come but good to see p5curly and freshp5 today as well as meet Jamie. Jamie and My son Dan played Lego whilst we talked kits but most importantly I have to thank Steve for the gearbox mount adapter plate. Engine is now sitting how I want it with what looks like no further modification to the dog bone mount. I'll finish drilling the plate and chassis tomorrow once I have a new 12mm bit, then paint the plate ahead of final fit on Wednesday. This will free up the crane for nate78 to borrow, which in turn gives me the space to trial fit the body work. sorry I'm not that regular with the photos but I'll have some this week for you all!
Post by p5curly on Jan 31, 2016 18:20:10 GMT
Good to see you again and Jamie loved the visit we ended up buying some more Lego for him this afternoon It was good to catch up and see your sketch you sent me a worth while trip
Post by mawdo81 on Feb 4, 2016 18:09:47 GMT
Any suggestions on best jacking/ stand points for the sonic to fit the panels please? Is it the rear and fore most chassis cross members? Does that interfere with fitting the rear? Was thinking the member at the front of engine bay/rear of cockpit but worried about the tipping weight of the drive chain...
Post by martinw on Feb 4, 2016 18:48:46 GMT
I built mine on a very wobbly trolley (I'm too embarrassed to include a picture.....!) which "evolved" over time. The final evolution was to add longitudinal wood (2 pieces of about 2" x 3") to lift the chassis off the trolley to allow the panels to clip underneath the sides. Effectively it was supported along its length from the front chassis member to the chassis member in front of engine compartment. You need to make sure that where you're supporting (particularly at the rear) isn't going to obstruct the side panels (they are attached to the lower chassis side members in the engine compartment). I didn't have any issues with it falling off.....mind you, I always kept my fingers crossed, and held my breath a lot. Seriously, though, if you do support in front of the engine compartment, it's probably worth making sure you've got something weighty right at the front of the chassis to provide a suitable counter-balance. Martin
Post by mawdo81 on Feb 16, 2016 21:35:16 GMT
I'm not the best at putting up pictures; partly because I'm not the best at taking them in the first place. But this is a key moment I wanted to share and I know others are asking about so: Nothing bolted or trimmed yet but feels like a little milestone! The side panels took a surprising amount of persuasion but actually a windscreen removal tool was useful to get in where fingers were too big!
Post by maz27 on Feb 16, 2016 22:50:15 GMT
Looking forward to spraying this now it's going to look killer
Post by p5curly on Feb 17, 2016 18:26:42 GMT
Looking good looks like you made some good progress since last time we visited
Post by mawdo81 on Feb 25, 2016 20:19:38 GMT
So first cut of the oil sump: And the spacing of the pick up pipe may suffice to mean that doesn't need modding Unfort unfately I can't offer the sump up with the pipe in position so will have to wait to lift the engine an inch or two!
Post by Stiggy on Feb 28, 2016 9:36:46 GMT
I am struggling to see why the sump needs modifying. Perhaps the chassis is different in some way to others or the engine not central.
Post by mawdo81 on Feb 28, 2016 9:40:06 GMT
I'm using the mtx 75 box. Which must be wider than the ib5 as to centralise the driveshafts as previously recommended I've had to shift to the right slightly.
Regardless of that the sump was only a mil or two from the rail prior to moving.
Post by mawdo81 on Mar 14, 2016 15:07:59 GMT
Can any sonic owners please measure both the width under the wing please and the length of the front edge of the wing? Thanks!
