Post by rossco on Mar 20, 2014 13:34:11 GMT
Hi everyone, Just started the acquisition of components to build my Rocket. Wanted to post as many photos of parts as possible to try and give a clear and concise build diary. So here goes......... Chassis ordered with delivery approx end of April. Donor ST170 RS Focus gearbox TTV Flywheel ATI Procharger supercharger
Post by Deleted on Mar 20, 2014 15:35:14 GMT
I like those parts.. Much.. So glad I have a flywheel like that.
Post by rossco on Jun 23, 2014 14:40:17 GMT
It's been a while since I have posted but havn't had much to post till now. Moved house and time seems to fly by and I havn't even lifted a spanner......
Also decided to go the whole hog and invest in a full focus RS engine setup. Motor is in pieces ready to go off to the my local engineer for a few minor bits.
Collected my chassis from RTR a month ago and have been accumulating parts ever since.......
Just in the process of ordering a floor material as an alternative to the supplied alloy sheet. Having the sheet machine cut at my local printers after there man comes and templates the floor.
Decided to use dibond a sandwich of two alloy sheets and a composite centre. Is stonger and lighter than the supplied sheet. And looks the business too.
Pictures to follow soon.
Ross
Post by airforceone on Jun 23, 2014 14:52:52 GMT
Does the Focus RS engine fit in the rocket?
Is it the older 2 litre engine or the new 2.5 turbo one..
Post by rossco on Jun 23, 2014 15:54:49 GMT
Yes it just a modded zetec. It's from a 2003 MK1 RS
Post by airforceone on Jun 23, 2014 15:56:01 GMT
Right, so it's basically a modded ST170.
Post by rossco on Jun 23, 2014 16:49:15 GMT
Doesn't have vvc but a turbo instead. They make about 215hp from the factory but have upgraded internals and are capable of running near 400hp without internal mods. My engine has only done very low miles under 20k and will have a fresh set of mains and rings. Head overhall and polish. My intention is to run the rotrex charger like Mabbs. So should achieve 350hp+ with any luck.
Post by Deleted on Jun 23, 2014 17:54:35 GMT
Doesn't have vvc but a turbo instead. They make about 215hp from the factory but have upgraded internals and are capable of running near 400hp without internal mods. My engine has only done very low miles under 20k and will have a fresh set of mains and rings. Head overhall and polish. My intention is to run the rotrex charger like Mabbs. So should achieve 350hp+ with any luck. Change the rods if aiming for 350hp or more.. Otherwise expensive mess there will be ( in yoda voice) At least change the big end bolts for ARP's;)
Post by rossco on Jun 24, 2014 21:56:14 GMT
Post by dgibson on Jun 25, 2014 22:27:03 GMT
Very nice - look forward to seeing the progress.
Post by rossco on Jul 1, 2014 15:27:44 GMT
Ok some minor progress. Engine completely stripped and cleaned. Block repainted black First half of the sump painted silver. Crank and all internal parts stripped and checked. ACL aluglide bearing sets ordered ARP Main, rod and head bolts/studs ordered. Full oe engine gasket set ordered Cometic head gasket ordered So moving slowly forward....... Speaking to my main man Garth Wong today from MGT racing in Nuneaton he has suggested a few ECU's to pick from. He will be doing all the wiring as I am just not into it and want the project finished before i'm old and grey........... Link Storm plus Vipec I44 Syvecs S6 Hopefully more progress later this week. Engine build and floor installation.
Post by Deleted on Jul 1, 2014 17:53:49 GMT
Sweet..
When you fit the arp main studs, they may foul the webbed alloy mid sump thing. A die grinder help remove the small areas in the cast that conflict.
May be sorted now, I built mine 8 years back, and they came from the USA.
Post by rossco on Jul 2, 2014 15:35:56 GMT
Thanks Steve, I will look out for it.
Post by Paul (madeye) on Jul 14, 2014 18:16:00 GMT
Post by rossco on Aug 4, 2014 9:49:32 GMT
Dibond floor now complete ready to install..... Also refitted crank with acl bearings. Polished and checked.
