Post by marks on Apr 19, 2019 13:53:35 GMT
I’m not sure how to post pics so hopefully an explanation will do. I’m stripping an 2002 1.8 mx5 and before I pull these plugs I need to identify them.
Plug 1 - sits on top of the cam cover closest to the front of the car on the left side as you look at it.
Cluster of three plugs - as you look at the engine these three plugs with wires coming up from the bottom of the engine sit just below the cam gears on the outside of the cover on the left hand side. Cluster of 3 right next to each other.
Thanks
Mark
