pxr5
Newbie
Post by pxr5 on Dec 8, 2018 22:02:12 GMT
I picked up a burnt out Rocket, no history or doc's, I thought the engine was a Zetec but its not, looking at the rear of the car, the twin cam belt is at the right, the exhausts are rear most, the engine is on carbs maybe R1's?, they are on the side between the engine and the seats.
Ive googled it, I thought maybe a Duratec but Ive not found any pics that look the same....It looks like a Zetec with a Duratec head? Im confused...Any ideas? thanks
pxr5
Newbie
Post by pxr5 on Dec 9, 2018 0:45:01 GMT
I have it, its a Duratec, as fitted to a fiesta etc..
Post by casesensitive on Dec 10, 2018 13:52:55 GMT
My 'Duratec' ST170 is in fact a Zetec-E with some funky marketing, labeling them 'Duratec' on the rocker cover (I've pulled it off). Same as the MK1 Focus RS, they couldn't be seen to be throwing the same 2.0 into their higher end products, so they did some badge engineering. Looking from behind the car, the inlet is facing you, the exhaust is facing forward, belts are on the right (the offside), gearbox is on the left (nearside). Actual Duratecs are, as you describe, exhaust outlet facing backwards, inlet facing the passenger cell.
pxr5
Newbie
Post by pxr5 on Dec 10, 2018 21:36:32 GMT
Its actually a Zetec SE, not really a Zetec, very strange naming by Ford.
Post by kiwicanfly on Dec 10, 2018 23:21:03 GMT
There's the Silvertop Zetec the Blacktop Zetec and then the Zetec trim/styling for the cars themselves. Figure someone in Ford REALLY likes the Zetec name or they got to Z in the alphabet and went into meltdown
pxr5
Newbie
Post by pxr5 on Dec 11, 2018 1:41:37 GMT
I need new poly / rubber A arm bushes, any good deals about? thanks
Post by casesensitive on Dec 12, 2018 8:20:37 GMT
Its actually a Zetec SE, not really a Zetec, very strange naming by Ford. Ah, the old Sigma engine? My first car was a Ford Puma, with the Yamaha-developed 1.7 Sigma/Zetec-SE. The naming is mental, its attached to several completely different engines as well as a a basic trim line. AMG and VAG doing something similar now. The 1.6 variant existed in the contemporary Ford Fiesta (MKIV; all of them here). Burton Power have pictures of all the Ford engines here. Now here's where it gets interesting, if you really have a Sigma/SE, it's probably a 1.6 from a Fiesta, super light, about 99hp. I've never heard of one with the 1.7 with VVT (123-125hp), and they didn't make anything bigger than that in petrol. The powertrain is light enough to lift without a crane/hoist once separated. The Duratec-branding on Focus/Fiesta engines didn't come in until the next generation, and there were both 1.8 and 2.0 versions of those.
pxr5
Newbie
Post by pxr5 on Dec 17, 2018 12:10:27 GMT
Thhanks for that, I was going to use a bigger Zetec engine, but having read about the Se I think it would make a great power unit with a turbo added..... BTW,Ive not found the chassis number, is it on a plate or is it stamped on the frame tube? under the bonnet? thanks
Post by casesensitive on Dec 18, 2018 10:19:53 GMT
BTW,Ive not found the chassis number, is it on a plate or is it stamped on the frame tube? under the bonnet? thanks Mine is on a plate, welded out of sight here, under the bonnet
Post by carlyd on Dec 19, 2018 14:14:14 GMT
Thhanks for that, I was going to use a bigger Zetec engine, but having read about the Se I think it would make a great power unit with a turbo added..... BTW,Ive not found the chassis number, is it on a plate or is it stamped on the frame tube? under the bonnet? thanks It should be stamped into the cross member of the chassis where the pedals attach to the chassis.
pxr5
Newbie
Post by pxr5 on Dec 19, 2018 19:53:19 GMT
Ok, thanks
