Help!
Nov 16, 2018 17:10:21 GMT
via mobile
Post by ian85 on Nov 16, 2018 17:10:21 GMT
Hi
Got my Exocet started up yesterday, but has a engine management light on. Plugged a diagnostic tool in today and the engine stopped and blow the engine management fuse 15a in the fuse box. Also there is 12v coming down the all black wire to diagnostic socket, which I am sure it shouldn't!. Any ideas or has anyone had this before
Help!
Nov 16, 2018 17:43:53 GMT
via mobile
Post by sheffjohn on Nov 16, 2018 17:43:53 GMT
What year is the donor wiring?
Help!
Nov 16, 2018 17:53:44 GMT
via mobile
Post by jason82 on Nov 16, 2018 17:53:44 GMT
Check for a trapped wire, it sounds like a dead short. Check where the loom runs tight to the chassis etc in case of chaffing.
Help!
Nov 16, 2018 21:33:39 GMT
via mobile
Post by ian85 on Nov 16, 2018 21:33:39 GMT
It's a 2003, I can't work out how I have 12v down the all black wire! It's pin 4 on the diagnostic socket
Help!
Nov 17, 2018 9:37:16 GMT
via mobile
Post by jason82 on Nov 17, 2018 9:37:16 GMT
Black wires are earths. It sounds like a short. Do you have 12v down the black wire before the ignition is turned on or after ? This will help you to diagnose which circuits to look at. Once you know whether it's a permanent live or a switched live that is causing the issue, start pulling fuses until the fault goes away. This will tell you exactly which circuit(s) have the fault, then simply follow the wiring by hand until you find the fault. To be honest, once you have a positive feed going down an earth wire to the ecu, it may blow the computer. There are very sensative components in there. There is no real fast way of trouble shooting, I am an electrician by trade (domestic & industrial, not an auto electrician, but the principles are the same). While doing your checks, also check that wires are terminated properly onto their correct locations. It's up to you if you follow my advice, just trying to help.
Help!
Nov 17, 2018 10:15:14 GMT
via mobile
Post by sheffjohn on Nov 17, 2018 10:15:14 GMT
If you replace the fuse and remove diag tool, does it start run and behave as before? I have zero idea how 12v on one of the shared earth's there even allowed your car to run to be honest.
Post by ian85 on Nov 17, 2018 13:05:55 GMT
Thanks guys for your help! I have now sorted the wiring fault. It has taken 4 hours of my life, but I found the problem a couple of hours ago and have sorted it!
After removing the tape around the wiring loom near the end bonnet diagnostic socket, I found two wires had rubbed through and touching each other!
What are the chances! Could believe it,pulled them apart and it started up and engine management light went out.
