blacksweeper
Junior
Currently building a top level Exocet
Post by blacksweeper on Sept 25, 2018 2:46:25 GMT
Post by garman on Sept 25, 2018 12:04:19 GMT
Wow! So clean. Can't wait to see who finishes first!
blacksweeper
Junior
Post by blacksweeper on Oct 2, 2018 2:33:38 GMT
Eibach anti roll bar fit issue. Just a heads up - I am using the Eibach anti roll bar kit PN 5530-32 from Tire rack. Its the same kit used on all Spec Miatas. No issue with the rear bar. I tried installing the front bar today. The problem is the bar has two metal rings built into it to keep the rubber bushing in place. These rings hit dead center on the chassis mounting brackets for the bar. Therefore you can't mount it. These work on Miata's but don't work on my Exocet frame. The rings look like they are crimped in place. I am going to try to cut them off with a Dremel tool. So just a heads up if you plan to use the Eibach front anti-roll bar. Thanks
Jerry
blacksweeper
Junior
Post by blacksweeper on Oct 9, 2018 21:20:30 GMT
What wheel offset is everyone running? I was going to buy the 949Racing Exocet wheels 15 x 9 with +12 offset but they are out of stock and no ETA on future availability. Lots of nice + 35 wheels out there. What is everyone running. Thanks for your help/
Jerry
Post by garman on Oct 11, 2018 21:23:19 GMT
Hey Jerry
I just went with some cheap MST M11 15x9 0 offset that are supposed to fit just fine. I also have some 25mm spacers for the rear.
The MST'M11's are basically the same JNC 003's that Exomotive sells on their site.
The wheels get here next week so I'll let you know how they look and fit as soon as I get them mounted up.
Right now I've got 15x6.5 40 offset Koenig Heliums with 225 Hankooks and there's about a quarter inch clearance from the rear frame with no spacers. I'm thinking of selling them as soon as I get the new wheels in.
blacksweeper
Junior
Post by blacksweeper on Oct 15, 2018 23:27:56 GMT
Thanks for the info Gary. I fitted some 15 225 on +36 offset wheels I had for my autocross car onto the Exocet. The tires only had ~ 1/8 inch clearance in the rear. Having to run a zero offset or spacers effectively increases the cars track 2- 3 inches depending on offset and spacers. That's a major design flaw in the kit. Let me know how the new wheels work out. Thanks for your help. Jerry
