Post by bigpaul on Jul 11, 2018 16:42:29 GMT
Just returned from the Le Mans Classic in the Rocket and developed a vibration under braking, assumed it was a disc but on removal noticed the off side hub was grinding, so obviously need to replace the bearing, it appears to be the Cortina set up, but does anyone know if there is any difference in the bearings between the various Mk's or which one I should get, going to swap out the discs at the same time
Thanks
Paul.
Post by Stiggy on Jul 11, 2018 22:03:24 GMT
I'm guessing you mean the front, Cortina MK 3,4,5
Post by bigpaul on Jul 11, 2018 22:30:41 GMT
Yes thanks Stuart
