Post by Stiggy on Jun 20, 2018 14:29:03 GMT
avi
Newbie
Preparing to strip
Post by avi on Jun 20, 2018 20:08:32 GMT
Not working for me ?
Post by Stiggy on Jun 20, 2018 20:40:03 GMT
Post by ciaoberto on Jul 15, 2018 19:02:44 GMT
Can't open the download. Has much changed?
Post by miket on Jul 28, 2018 8:31:24 GMT
I just had a quick scan of the new Guide (I'm still working on a "classic" version of the Exo) and noted changes that made reference to the things listed below in case it helps anyone - but this isn't necessarily and exhaustive list:-
Roll bar dismantle / refitting. G-type panels. 32mm / 30mm spacers and related notes. Steering column length adjustment. Power steering removal options. Bulkhead trimming guidance. Cover for handbrake cables. Shocks / bananas. Mk1 Radiator / brackets. Harness bar.
Post by symo76 on Aug 4, 2019 16:36:19 GMT
Post by symo76 on Aug 4, 2019 16:40:30 GMT
Hi i am a newbie and i am about to buy the following parts from a mk3 i will replace the brakes and suspension myself can you guys recommend any other parts i would require look forward to any help or advice
2.0 litre engine complete ready to install £500 6 speed gearbox £275 LSD diff £250 Propshaft £20 Rear subframe with suspension arms £45 Driveshafts £40 for both Both Rear hubs £40 Front subframe with engine mounts £45 Above includes alloy support frame running down centre of car Lock set, key, Ecu, speedo £60 Complete wiring loom £45 Pair of front hubs £45
