Post by Stiggy on May 24, 2018 9:25:34 GMT
We now offer an upgrade to projector headlights, supplied as 2 pairs. They are E marked and dip to the left. Full projector lighting kit for G-type includes 2 left dip and 2 main projector headlights in alloy cases, 2 LED side repeaters, 2 LED side lights, 2 LED front indicators, 2 rear reflectors, 2 rear LED stop/tail/ind, 1 rear E and F marked fog light, 1 LED reverse light. £379 plus VAT. Standard kit with 2 Dominator headlights £249 plus VAT. Builder will need to make brackets to bolt the headlights to the headlight brackets on the chassis, no welding required.
Post by hammy3601 on May 24, 2018 12:31:11 GMT
Hi Stuart, Are the 2 rear LED stop/tail/ind available in red or only in clear?
Thanks John
Post by Stiggy on May 24, 2018 12:56:30 GMT
The rears are clear, they look better than with a red and orange part side by side. As they are mounted at an angle the indicator part can be upper or lower. They don't look like indicators until they light up.
Post by hammy3601 on May 24, 2018 13:25:09 GMT
Thanks
Post by kiwicanfly on May 24, 2018 19:27:32 GMT
Exo sell a single projector headlight unit with dip and full in one housing, have you looked at supplying thoose?
Post by Stiggy on May 24, 2018 19:46:54 GMT
Exo sell a single projector headlight unit with dip and full in one housing, have you looked at supplying thoose? Of course, I got a box of 30 in my case when I went to China years ago. They have a shutter and a single element bulb, fine if you can be bothered to wire in diodes to keep the bulb on when you select between dip and main, get it wrong and back lights go off too. With MX5 switch gear it is easy to wire the pairs in and they look real cool and mean with 4 units mounted. To me one each side looks weak, almost like it's off a push bike. Each to his own. Paul will sell you a pair especially now he has met you and has seen how lovely you are really.
Post by kiwicanfly on May 24, 2018 22:32:17 GMT
Of course, I got a box of 30 in my case when I went to China years ago. They have a shutter and a single element bulb, fine if you can be bothered to wire in diodes to keep the bulb on when you select between dip and main, get it wrong and back lights go off too. Wouldn't the dip/main switch not simply control the shutter with the bulb left constantly illuminated while the lights are on? With MX5 switch gear it is easy to wire the pairs in and they look real cool and mean with 4 units mounted. To me one each side looks weak, almost like it's off a push bike. Each to his own. I personally prefer the look of a single light but after lots of research could not believe it was possible to obtain both functions in such a single small unit based on everything else in the market. After experiencing the usual Dominator units I am now very wary of claims made by manufactures as to the suitability and legality of most of them on the market. Paul will sell you a pair especially now he has met you and has seen how lovely you are really. Aw shucks Stuart I dont know what to say
