Post by ine3d on May 4, 2018 23:40:57 GMT
Evening All, Anyone added tow points to their sonic? I need to add them for track days but wonder if anyone has a thought or experience on where and what to use? 🤗
Post by buildityourself on May 7, 2018 19:55:20 GMT
ine3d I've briefly thought about this, and saved these from the donor in case they could be welded somewhere suitable as they look pretty suitable. They are the rear seat backrest brackets. Are you currently building a sonic7 or is it already finished? which is your thread?
Post by Stiggy on May 8, 2018 10:05:50 GMT
towing is possible with all sorts of hooks, this guy uses his privates!
Post by ine3d on May 19, 2018 9:26:53 GMT
Not sure about adding plumbs to the front of the car...
Post by drbrian on May 27, 2018 2:45:23 GMT
YEs I did I used these on the front and back of the car frame. Then I let the people put the tow hook on to it. It was pretty easy but I had to make a second plate to clamp around the square frame.
