Its been a really productive week. To start off I approached a company called Forest fasteners for some technical advice on how tight these chassis bolts should be. Very quickly I had the reply 90nm dry, so that was brilliant to have a definite answer from someone in the fastener world, so that's qualified enough for me !
Next up I had my dominator 2 headlamps come through from a company called on ebay called mbs ltd. They were the cheapest that I could find in the uk & were £235.98 for 2 pairs, delivered. The item number is : 253702466122, the service was amazing & they were delivered in double quick time. They are very well made & are quite heavy, so I am a happy lad. After an email exchange with iva technical, I was told that they are fine as long as you have a set of dlrs fitted. My dlrs (Phillips daylight 9) were £62, so that's £300 for the set up.
I had a few issues mounting my fuel tank, basically the rear panel would not completely cover the tank and it sat up a bit at the back. I rectified this by mounting the tank underneath the chassis & butted up to the factory fitted mounts. I mounted my tank with the filler on the passenger side rather than the drivers side, because I did not like how tight the fuel filler hose was, and I anticipated that it would take ages to fill the tank, due to the tight bend. The rear cover fouled whatever way I mounted the fuel tank with it mounted on top, but I must say, things fit a lot better with it mounted underneath.
I had to drill the tank on two of the four mounts, this was not an issue as I drilled through the flashing. I drilled a 9mm hole, then used an M8 bolt from the top, with a thick rubber washer between the tank & chassis, then a large washer with nyloc underneath. Initially I was worried about clearance between the tank & rear subframe, but with my mk1 tank, it fits nicely. On the one corner where I could not drill through the flashing due to not enough material, I used the existing hole bolted to a piece of 3mm steel plate, then bolted it to the nearest mount.
I have ordered a 51mm x 500mm fuel hose from CBS, which will connect my fuel tank to the petrol cap. At the moment I am using the standard MX5 fuel cap & gubbins, but I may change this for a nice billet one from kitspares. The trouble is, it needs to have the breather pipe adaptor & the set up will cost around £170. A cheap option that I have come across is on ebay, if you type marine fuel caps into ebay, you get some really nice boat ones that will fit perfectly & are a fraction of the cost.
I simply ran a hose to atmosphere with a check valve connected to it from the vent outlet on the tank.
I then made a strap out of aluminium to keep the fuel filter from flapping about & bolted it to the mounting point (not in this picture), then fitted a 15mm copper pipe connector to the corner tank mount to keep the fuel lines nice & safe.
I had pre drilled the ppf months ago with a 9mm drill bit, at 200mm intervals, where I used an M8 x 40mm bolt to bolt the pipe clips to it. I ran the fuel pipes down the driver side of the ppf, where they fit snuggly. If you use this method, you will also need to drill the plastic pipe clips out to 9mm to accept the M8 bolt. I used M8 bolts as I was a bit worried that M6 bolts may fatigue & break off with the weight of carrying two fuel pipes (flow & return).
What is not very clear in this picture is that just above the fuel clips is a 7mm hole drilled at the same 200mm intervals, where I can use an M6 bolt to secure the brake pipe clips to the ppf. I have used stainless clips with a rubber insert to wrap around the 3/16 brake pipe as it will be more robust than the cheap plastic clips.
The pipe has two further clips not shown in this picture, one is right on the corner of the chassis rail, & with the other clip, I put a bracket on the very front of the ppf, where there is a c section cut out, where it bolts vertically to the gearbox.
I purchased 8m of 8mm i.d high pressure fuel hose from Kitspares months ago & it was just right. Basically i ran the first piece of pipe from the middle outlet on the tank (feed) down to the fuel filter to the 'in' port, then ran one continuous line from the filter, to the engine bay & looped it back up to the return on the tank, this way i can cut the pipe in the engine bay wherever i like. 8 meters was perfect, this left a really nice sized loop in the engine bay ready to be connected to the engine. To make things easier, i ran the feed along the top of the pipe clips & return along the bottom of the clips so that i do not plumb the pipes wrong.
The fuel pipes will be run straight to the fuel rails instead of using a barb fitting, connecting my new rubber hose to the old one. As an electrician, i hate joins as it is a source of a potential problem. To help me with this, i have not mounted my intake manifold to my engine, this way i have direct access to the fuel rail
Next up was the handbrake & cables. This was a bit of a pain in the butt as i had to open up the holes where the handbrake cables pass through on the gearbox tunnel. The holes are way too small, its not a powder coat issue as i had to use a carbide grinding bit in my drill to remove the steel, opening up the holes. Once they were opened up enough to fit perfectly, i came across another problem. The bracket that the cables passes through is too thick for you to put on the handbrake retaining clips & required a little bit of attention to get the retaining clips to fit.
With the two handbrake cables now fitted, i coupled them up to the short handbrake cable, put the handbrake in the down position, & wound the adjuster screw on the handbrake all of the way in. This way i have maximum adjustment at the handbrake. With the short cable pulled taught (handbrake in off position), i then marked where the mounting points of the handbrake was located, then drilled them out to 9mm to take an M8 bolt. As the gearbox tunnel was off, it was easy to get my hand on the nuts in the tunnel. I could have used rivnuts on the handbrake, but i felt that the handbrake would need something a bit more significant.
The handbrake was later removed, sanded down & painted in gloss black. Further more, the little cable clip between the handbrake handle & the 2 into 1 joiner was secured by drilling a 7mm hole into the gearbox tunnel, i then used a piece of chrome tube to go between the chassis & this clip keeping it secure with an M6 bolt ( not in this picture).
Finally, i got all of my wishbones mounted, steering connected (using brand new tie rods & track rod ends) & the wheels & suspension fitted. It was really nice to finally get this thing rolling & steering like a car.
The anti roll bars are not connected in this photo, but they will be. I had also not lined up & torqued down the wishbone adjuster bolts, as i was having a spot of bother trying to locate the picture that i took of them when i stripped my donor, but to be honest, i will get the car re aligned to MX5 specification, as its on standard suspension & its all identical to how it was on a standard car.
At the start of the build i was really concerned about how the suspension gave the appearance of drooping on kits that i have seen before, caused by using lowered suspension. I looked into getting the shock tower mounts from Exomotive shipped over here, but then i decided to scrap the lowered suspension kit that came with my donor & replace it with original MX5 shocks & springs. This proved to be a good choice as the wishbones are now parallel to the ground & gives a nice ride height.
I will be hitting the kit hard again this weekend as i will hopefully be getting my iva date through the post. I also have a week off work coming up where i plan to get this finally finished.
My build initially was really slow due to refurbishing parts etc, and the chassis & panels sat fairly untouched. I went through a period of putting in loads of hours with no visible progress, & then all of a sudden i find myself simply bolting on finished parts & my progress has been fairly swift. If i could give any builder one piece of advice, it would be to make a to do list. This sounds really lame, but put even the tiniest of jobs on the list, this way you can visibly see progress. I have hit this wall before & my Haynes Roadster got shelved for almost a year.
Even if you have 5 minutes free, pick a really small easy job & you will see the difference this makes. My must have tool for the build has been my camera. I originally started stripping my donor 10 months ago, and at the time i knew where everything went, but now i don't. Take random pictures of everything, as it may prove key to how something goes back together, especially when doing an engine rebuild.
Happy building !
