turbo2015
Junior
Looking to buy a Rocket...get in touch!
Post by turbo2015 on Dec 24, 2017 19:03:49 GMT
Hi Guys
Im either looking for a winter bargain or a rough, damaged Mev, etc for the right price.
Blown engines no problem, as im likely to put in a s/c honda engine.
Thanks Again.
Post by carlyd on Dec 27, 2017 14:39:49 GMT
Hi Guys Im either looking for a winter bargain or a rough, damaged Mev, etc for the right price. Blown engines no problem, as im likely to put in a s/c honda engine. Thanks Again. You make it sound easy fitting a Honda engine, trust me as one of the only two rockets with a Honda engine I did it and it's not. it's very different from the ford engine but in my opinion well worth it, the main differences are, Engine mounts, driveshafts, wiring (ECU etc), exhaust, cooling system, gear linkage and cables, virtually everything is different, and depending which Honda engine you choose some sit the opposite way around to the Ford engine (exhaust manifold towards the front of the car), therefore retro fitting a Honda engine is going to be very time consuming and expensive. I would thoroughly research it first if I were you. Good luck with it.
Post by airforceone on Dec 29, 2017 21:01:12 GMT
Have a look at the for sale section as I've put a price on mine now if your interested.
