Post by buildityourself on Nov 25, 2021 20:24:16 GMT
Cycle wing brackets
We used Ford Cortina uprights instead of the normal kits Rally design alloy uprights (decided against these due to mixed reviews on the forum). This meant that the supplied cycle wing brackets were not suitable so replacements were needed. I purchased plates suitable for the cortina uprights from kitspares.co.uk/. Then had some 12mm round bar bent at right angles for the arms. The plate was offset from the hub using round tube with bolts running through to have the same distance between the bars and wheels as the rear wheels. The bars were clamped to the plate and I tack welded these in position.
I checked the clearance to the body and headlight and it was ok.
With one bracket done, the other was mirrored for the other side.
Fitted them both to the car to check the passenger side.
This side touched the headlight though, so after lots of checking this seemed to be caused by the steering rack. Despite previously spending much time setting up the rack so that the steering wheel turned exactly equal amount to the left/right on full lock it seems that turning to the right means that the left wheel is closer to the chassis. This is either down to the tracking not being parallel as measured or the rack brackets not being quite in the right place in the chassis. I've managed to adjust the toe to avoid it hitting and still be parallel but am at the limits of the track adjustment, and now the steering lock is different between the sides on the wheel. This will need further investigation.
I'd be interested in the distance of the rack bolt holes from the outside of the chassis bars on each side on other owners cars.
Due to the bar size my welder was not up to fully welding so these were welded up and a curved brace bar added by the local blacksmith. I intended the curved bars to match the arc of the wheels , but they didn't quite get this right.
I'm happy with the overall design though as it avoids a piece of angle iron bolted to the upper ball joint used in the old MEV/RTR kits.
Luckily the brackets would just fit in the oven for powder coating but due to the shape could not be hung.
Final fitting to the car.
Next update the cycle wings.
