Post by casesensitive on Sept 11, 2020 13:08:14 GMT
I've cut my up recently to fit a better pump solution, and it's definitely not dual anything, it's 1.5mm Al seam welded in a sort of a wedge-shape. For those looking to find the capacity, run your fuel pump with the return to a jerry can till it's completely empty. Then add measured fuel carefully until its full. I calculated my tank would have 28l by measuring the outside, but it was more like 25l when I went to pour the stuff in. As its irregular, if you want your % left to be accurate all all times, you'll need a Spyda or similar, which I have. mevowners.proboards.com/post/110255/thread
