Post by colinm2 on Jun 15, 2017 19:51:20 GMT
Does it matter which way round all the wishbone bolts go in?
Post by mikeeyboy on Jun 15, 2017 22:02:54 GMT
I cannot comment from a structural point of view but double check the fronts before you put them on.
If the bolt goes in from the back side you cannot get them out once the chassis is bolted down, the tubework is in the way.
Post by gwnwar on Jun 15, 2017 22:09:00 GMT
Top front in from front easier to remove if need be, The camber bolts lower control arm both front and rear go in with bolt head to the inside nuts out side. Rear top inner from inside..
Post by colinm2 on Jun 16, 2017 9:50:18 GMT
Great thanks for your help
