Post by makoto on May 12, 2017 9:42:27 GMT
need some insight, I think I made the biggest mess ever...pretty painful. Ive unscrewed the wrong oil full plug...😩...now I have no gears, not going into any gear at all, tried to put it back but no go. Did some research and seems the only way to fix it, is to remove gearbox....what a pain. Is there any easier way around it at all.... . 😭😭😭😭
Post by theancientone on May 12, 2017 13:41:21 GMT
Post by makoto on May 12, 2017 13:53:29 GMT
Yep that is one I've picked up on.... painful. Doesn't look like there's any way out
Post by Stiggy on May 12, 2017 13:55:39 GMT
Yikes, that is an issue. I have not heard of it but apparently common. Is it possible for you to add pictures of which one not to unscrew, hopefully JP will pick this up and add it as a sticky to the build guide thread as a warning to others.
Post by makoto on May 12, 2017 13:59:24 GMT
Post by makoto on May 17, 2017 21:29:23 GMT
Update: Got the gearbox out and managed to get it fixed for £50 . Had to be taken apart to replace the shaft. Prob best to get the clutch done whilst its out.
Post by gwnwar on May 17, 2017 23:41:25 GMT
Best thing to do if you have a 6 speed is fill the hex hole with RTV sealant and paint it red.. or make a cover plate to cover the bolt and secure it in place with a case bolt..
Post by ritchie624 on May 18, 2017 11:30:24 GMT
Who would have thought... PDF added to my library, don't want to make that mistake😳
Post by makoto on May 18, 2017 20:21:07 GMT
Definitely getting the red paint out gwnwar!!
