Post by bighec on Dec 31, 2016 3:49:46 GMT
Morning folks,
I am on the scrounge for some information on the rear lights for the Mevster. I understand they are made by Hella but can anybody provide me with a part number??
I hope you all have a great new year,
Regards,
Hec
Post by p5curly on Dec 31, 2016 8:04:34 GMT
You will find it hard to get as SVC are not getting them from the states any more you may want to text my bro Dave he may know another source As you will need the connectors for them too it makes it a bit easier to wire up too
Post by bighec on Dec 31, 2016 9:16:13 GMT
Cheers mate, hoping I can source even a part number so i can compare dimensions in a quest to find a suitable replacement. 😆
Hec
Post by Stiggy on Dec 31, 2016 12:03:46 GMT
the were Hella Premium from S-V-C. They are not the 55mm mix and match and not the 95mm dia ones. I think they were 65mm dia and we used clip on rims for them. Sorry but I am not aware of any other lights that are the same size as the "frenched in" holes.
Post by freshp5 on Dec 31, 2016 12:25:28 GMT
S-v-c have stop doing them
Post by bighec on Jan 4, 2017 19:57:57 GMT
the were Hella Premium from S-V-C. They are not the 55mm mix and match and not the 95mm dia ones. I think they were 65mm dia and we used clip on rims for them. Sorry but I am not aware of any other lights that are the same size as the "frenched in" holes. Thanks mate for the assistance.I have managed to source the part numbers with the kind assistance of our resident mevster pros! I will share the part numbers here for the benefit of others. Sourcing the actual light unit seems not to difficult, they are hella 66mm units. Itbis the clip on rims i am struggling with. Are you able to confirm if theses were hella clips or sourced elsewhere? Kind regards, Hec
Post by freshp5 on Jan 4, 2017 20:20:34 GMT
The rim at hella one mate
Post by bighec on Jan 4, 2017 21:13:40 GMT
Thanks gents, ok some success. Part numbers
Stop / Tail Light - 2SB 009 001 -061 Fog - SNE 009 001 -021 Indicators - 2BA 009 001 -001
All have an external diameter of 66mm.
According to the Hella website the snap on rings (of which there are different colours and Styles) are part number 9HB 161 122-007
I think makes up the components required for the rear lights.
Cheers,
Hec
Post by p5curly on Jan 4, 2017 21:28:57 GMT
Did you source the connectors for them too
Post by bighec on Jan 5, 2017 6:00:18 GMT
Did you source the connectors for them too Hi mate, fairly sure the part number for the connector is
HELLA 8JD 162 581-802
again they are available for numerous locations online. In packs of 20.
Cheers, hec
Post by kiwicanfly on Jan 5, 2017 7:45:49 GMT
I am really intrigued by this thread, can I see a picture of these lights please?
Post by Stiggy on Jan 5, 2017 18:56:00 GMT
Post by kiwicanfly on Jan 5, 2017 20:35:38 GMT
Cool
Post by bighec on Mar 30, 2017 21:20:24 GMT
Evening one and all, some of the information posted above has been slightly inaccurate. Below is the completed list required for the rear lighting.
1 x 60mm Rear Fog Light – Part No HELLA 2NE 009 001-021 1 x 60mm Reverse Light – Part No HELLA 2ZR 009 001-017 2 x 60mm Indicator – Part No HELLA 2BA 009 001-071 2 x 60mm Combined Stop / Brake Light- Part No HELLA 2SB 009 001-061 6 x 60mm Silver Bezel – Part N0 HELLA 9HB 161 122-007 (also available in Black and Chrome)
4 x Hella 2 Pin Connector – Part No HELLA 8JD 156 150-807 2 x Hella 3 Pin Connector – Part No HELLA 8JD 162 581-802 (Stop / Side light combo)
The connectors are available only in packs of 20 at a time.
Hec
Post by p5curly on Mar 31, 2017 9:51:42 GMT
Where are they supplied from hec
