Post by adelaideexocet on Nov 3, 2016 23:24:02 GMT
I'm interested to see what storage solutions people have come up with. I did see a NZ build that had some compartments for odds and ends and I'm looking at putting some small boxes behind the seats for things like tools, flat tyre fix, sunglasses holder etc. does anyone have pics or a description of what they did? This will also likely be used for the cover too.
Post by SeanW on Nov 3, 2016 23:30:05 GMT
I've seen a small Pelican case mounted to the floor under under the driver's legs for small things. I was considering running a top cargo box on mine since I've got the fully caged race-chassis.
Post by SeanW on Nov 4, 2016 3:39:11 GMT
I was thinking about it a little more this evening. It probably wouldn't be that hard to mount a metal .50 cal ammo box behind the seats. You can put a padlock kit on those to secure them closed.
Post by SeanW on Nov 4, 2016 3:49:30 GMT
Post by adelaideexocet on Nov 4, 2016 8:41:14 GMT
Post by SeanW on Nov 4, 2016 15:23:33 GMT
It just occurred to me that aluminum side panniers for for ADV motorcycles might work pretty well, too. I had plastic side cases on my old Triumph Tiger that worked well enough but, before I sold it to fund my Exocet, I was looking into getting a new set of side boxes similar to these... I need to check the dimensions a bit but it looks like something like this would fit relatively nicely against the back bulkhead behind my driver's seat. The medium size of these particular cases will hold 27L and measure about 36cm(H) x 19.05cm(W) x 45.75cm(L). There are a number of different models out from different makers. They're all a bit pricey however for form, function, and fitment with minimal effort something along this line might be the way to go.
Post by jwagner on Nov 4, 2016 16:25:18 GMT
I've got a plastic drybox on heavy duty velcro behind the driver's seat. Holds the reg papers, extra sunglasses, wheel lock key, etc.. Amazon has a bunch of options.
