Post by lukeg on Oct 12, 2016 22:38:13 GMT
I keep seeing build threads and exocet owners mentioning the slow gas filling issue with the factory fuel tank.
Is there a solution to fix this and allow normal speed fueling? And if so, what is it?
Thanks!
Post by clintavo on Oct 13, 2016 4:02:53 GMT
The fuel comes out of the pump hose foamy, and backs up in the shortened neck. I was thinking of a rigid vacuum cleaner hose inserted into the filler neck, and filled from the top of it. Anyone game to try?
Post by Stiggy on Oct 13, 2016 8:49:07 GMT
No problem at all filling as per below, all parts are from the donor. Watch out if experimenting with alternatives though, pipes need to be suitable for petrol.
Post by lukeg on Oct 13, 2016 18:05:11 GMT
The fuel comes out of the pump hose foamy, and backs up in the shortened neck. I was thinking of a rigid vacuum cleaner hose inserted into the filler neck, and filled from the top of it. Anyone game to try? Interesting... so the outer area would allow the air to vent at a faster speed?
Post by gwnwar on Oct 13, 2016 19:25:10 GMT
Have you tried another gas station.. Seems like station equipment high pressure and air getting mixed to cause the foaming bubbles..
Post by clintavo on Oct 14, 2016 3:46:57 GMT
I use whatever station is nearby. Some do seem to flow better than others, but still quite slowly. I can pull the filler out and watch the foam fill the neck, then rapidly retreat when I stop filling.
Post by lukeg on Oct 14, 2016 13:21:58 GMT
I'm buying an exocet, so I don't have one to dissect yet.
Would this be an issue on the exocet, or have those of you having problems already removed or modified the flip-over baffle?
Post by zeitgeist on Oct 14, 2016 17:06:57 GMT
I use all factory filler parts except I cut down the metal filler neck to fit under the Exocet cover. I also used longer vent hose and formed a 180 degree loop where it connects from the neck to the tank. I did re-use my factory anti reflow valve like the one in the video but on my 99 it is a 3 valve design like a heart valve. I can fill up at any of the local stations and several I have used to and from a trackday with no problems of speed or flow and no leaks while filling or on track. It works as good as stock Miata or better. My only fuel filling issue is when I use a gas can and have to stick the gas can neck deep into the filler neck and it gets caught when trying to remove it on the metal flapper right at the gas cap area. Not a big deal and no fault of the Miata parts or modifications.
Post by davetherave on Oct 14, 2016 19:30:36 GMT
I have this problem aswell can only get half a tank at most Need to make sure the forecourt floor is level otherwise i can get much fuel in but I have to have the novel out of the filler and fill slowly
Post by lukeg on Oct 14, 2016 23:42:21 GMT
Zeitgeist, can you please post a pic of your fuel tank setup?
Post by zeitgeist on Oct 17, 2016 16:22:32 GMT
There are pics in my build thread. I am in Tacoma this week so no access.
atv
Newbie
Post by atv on Apr 15, 2019 5:51:10 GMT
Anyone solve this one?
