Post by Shane on Sept 17, 2016 9:39:25 GMT
Right guys, I know this has been asked before, mainly because I've asked it, but unfortunately the suggestions I've had wont work in my circumstances. I need to buy wheel spacers (big ones) The best suggestion I had was to put 2mm washers on the bolts and keep packing out until the wheels fit perfect and then you know the spacer size based on the number of 2mm washers, simple The problem is, I got 8 washers on (16mm) and the wheels still needed spacing out, but there is no more thread on the bolt to allow me to hold the wheel in place to check the clearance. So i know I need a spacer bigger than 16mm, but how can I work out exactly what I need, they are to expensive to guess. These are the wheels: www.wheelbasealloys.com/alloy-wheels/calibre/motion-2/black-red/15-inchThanks everyone.
Post by kiwicanfly on Sept 17, 2016 10:33:47 GMT
Obtain the correct design specification offset and buy a spacer that makes the combined wheel/spacer offset match this.
Eg the Rocket is 35mm (some say 38 though) I bought some wheels with a 53 off set so the perfect spacer, in theory, is 18mm.
However, just to add a twist, a spacer that thick would actually need to be an adaptor, ie carrying it's own bolts. A simple spacer would not leave enough original stud thread protruding to be safe.
In this case an 18mm spacer is thick enough to space but too thin to enclose all of the original stud length which would then have fouled the wheel. Some wheels have pockets in the back to prevent this being an issue.
My solution was to use 25mm adaptors, thick enough to cover the studs and keep the resulting offset close to design, 28 instead of 35.
Post by johnp on Sept 17, 2016 11:00:48 GMT
Talk to Stewart who produces custom spacers and more for racing Exocets.
Post by squiddy1981 on Sept 17, 2016 11:47:18 GMT
second that just received a set and they definitely look the part.
Post by Stiggy on Sept 17, 2016 12:43:20 GMT
Simples; Aim for zero offset. If your wheels have a 30 Et (offset) aim for 30mm spacers.
Post by hutchey on Sept 17, 2016 13:53:54 GMT
I got 20mm spacers set (4) for £55 and they work great. My donor wheels are et45 and i reckon that even going for a wider tyre that I can go down to et20 wheels
Post by Shane on Sept 17, 2016 16:13:44 GMT
Thanks everyone, It was freakparts who advised the washer spacing idea, I am ordering from freaky. My wheels offset is 38, so I need a 38mm spacer. That is simples stuart Thanks
Post by Shane on Sept 17, 2016 16:33:35 GMT
Just checked and a 25mm spacer is cheaper and takes the offset to ET13 which i think is fine as the guide states ET15 is also fine.
Think Ill go for the 25mm spacer, need to start saving money somewhere, especially as we are moving home at the moment as well :S
Post by kiwicanfly on Sept 18, 2016 2:01:16 GMT
We're there no 0 offset wheels available to remove the need/cost of spacers?
Post by Shane on Sept 18, 2016 7:48:32 GMT
Unfortunately not ones that I wanted, I was pretty specific on the wheels I wanted
Post by p5curly on Sept 18, 2016 9:04:56 GMT
Where you moving mate
Post by Shane on Sept 18, 2016 11:06:14 GMT
Staying local mate, its about 1 mile away, tried to convince the missus to move to tamworth but she wasnt having any of it lol
Post by Stewart on Sept 21, 2016 16:17:53 GMT
When ordering custom spacers from us, give us a few weeks notice I don't like letting customers down, but a lot of the stuff we make is bespoke so takes time.
Post by Shane on Sept 22, 2016 18:54:16 GMT
Turns out the wheels they sent are actually 40mm offset so ordered 40mm spacers from freaky parts at £165 including delivery, that should take the wheels to zero offset. Fingers crossed all goes well
