Post by driver on Jun 30, 2016 20:12:17 GMT
Anyone know where I can purchase a slim radiator fan. Brought an aluminium rad which is thicker won't allow me to fit standard fan. 1.8 mx5 uk build thanks
Post by driver on Jun 30, 2016 20:55:31 GMT
On more question is the standard mx5 fan push or pull? Thanks
Post by gwnwar on Jul 1, 2016 2:56:06 GMT
It is a push or pull depends on how you have it wired. OEM wired it pulls reverse wires it pushes. Check eBay for fan units
Post by bignik on Jul 1, 2016 13:42:13 GMT
I had the same issue with my thicker rad, mine only fouled on the anti roll bar. I ended up using some 15mm angle aluminium and modifying the lower fan motor brackets.
Post by zeitgeist on Jul 1, 2016 14:37:32 GMT
I cut some clearance on the stock shroud brackets to clear the front anti roll bar for mine. Still plenty of material left. I may switch to an aftermarket single fan for even more clearance and less complexity if I run across one for a reasonable price.
Post by mawdo81 on Jul 14, 2016 20:48:19 GMT
If blades aren't symmetrical then the fan is designed for a particular direction...
