Post by driver on Jun 13, 2016 21:26:35 GMT
Can anyone take a pic showing how they routed the return and flow fuel pipes in the engine bay? Been 2 years since I worked on my exocet and little things are becoming an issue thanks peeps
Post by Stewart on Jun 17, 2016 11:09:14 GMT
I ran it wherever it would go, secured with a couple of P-clips. I have used braided from and back to tank through the inside of the car though rather than copper down the transmission tunnel.
Post by jgilbert on Jun 18, 2016 16:14:13 GMT
Can anyone take a pic showing how they routed the return and flow fuel pipes in the engine bay? Been 2 years since I worked on my exocet and little things are becoming an issue thanks peeps Driver, Its hard to get a clear photo, but see below. Supply and return run up along side the bell housing. I made a bracket and secured here. The hoses then past through the inlet manifold between the first/ second and second/ third inlet branch. This is the standard position in an MX5. I covered the hose in the original plastic conduit for protection.
Post by gwnwar on Jun 18, 2016 17:08:59 GMT
Remember the front of the fuel rail is the supply.. It comes from the center most of the tubes on the fuel tank plate..
