Post by gwnwar on May 12, 2016 17:24:06 GMT
Up and running great..
Post by squiddy1981 on May 12, 2016 18:04:57 GMT
thanks again. that could have cost me some £££££.
Post by gbob on Aug 31, 2017 13:40:09 GMT
Can I just confirm that it was the lack of air filter tubing that caused this? I've got the same symptoms but don't have mine plumbed in. Connectors are connected. (Threw out the tube by mistake)
Post by squiddy1981 on Aug 31, 2017 13:42:57 GMT
Yes as soon as I piped it in. it fired and ran
Post by rubix on Sept 1, 2017 16:20:47 GMT
Hi I had this same problem for the past two years people kept pointing out edu etc it's currently with an auto elec who is having no luck. Can you post a picture with the exact tubes you connected to get past this cut out after starting problem ?
Post by gwnwar on Sept 2, 2017 4:30:57 GMT
Rubix.. It would be the OEM plastic intake tube (black about 2' long)between the throttle body on the intake manifold and the AFM or MAF which ever you are using. AFM/MAF tells the ECU how much air is going into the engine intake and temp of air.. After the AFM/MAF you can run any air filter you want.. It will also help with problems you have if you has a signature line in your posts. see the Red White Blue in this post bottom..
