dmcd
Newbie
Post by dmcd on Sept 19, 2016 20:49:29 GMT
The trans is level and the kit body isn't on yet so have good access, am I safe to assume that if the oil is coming out of the fill plug there is sufficient in there? Thanks
dmcd
Newbie
Post by dmcd on Sept 26, 2016 22:23:53 GMT
I'm having problems lining up my steering column and struggling to see where I'm going wrong.
I can't get the column straight in the car because the hole in the bulkhead looks to be off centre this means I cannot bolt the top together it's rubbing the bulkhead and therefore the angles mean that where column attaches to the rack is fouled by the engine mount.
I have tried the column at different lengths and been playing with the mounting brackets to try a line it all up but it's still way off.
Are there any Exocets in Gloucestershire who would let me have a look at there setup?
Post by calibuild on Sept 27, 2016 3:54:18 GMT
Can you post pictures? If I'm understanding correctly, my build was similar, I just keep messing with it and finally got it right. Ended up pulling the steering mount to the far left (if sitting in the driver seat). Also helped bolting everything firmly down, then attaching the steering column.
