Post by miket on Mar 12, 2016 12:49:29 GMT
The Dim/dip resistor crops up occasionally on the forum – usually to get it identified. I think these were only fitted on early UK models. Forum consensus seems to have been that it’s not needed, but I wanted to be sure, so I test mounted one MEV-supplied Dominator headlamp. The light worked fine with resistor and relays in place, and then also worked the same when the Resistor, the Dim/dip relay & the linked Retractor relay were disconnected. The Retractor relay also has a looped connector and a redundant connector physically next to it that also look like they aren't contributing anything. Soooo ... does anyone know of a good reason not to (carefully) remove all the wiring to these? I.e. are there any known implications for other parts of the electrics? Dim/Dip Resistor, Dim/Dip Relay & Retractor Relay:- Retractor relay has other redundant 'stubs' next to it:-
Post by snowbird1 on Mar 12, 2016 14:37:20 GMT
Yes - you can get rid of it, I assume you will also be getting rid the retractor relays and wiring. I like to find uses for BLO (Bit Left Over) and did try using the resistor as a ballast for LED turn signals - worked fine but as it is only 1 OHM and flowed bit too much current for comfort! It's still sitting in the bits box.
Post by miket on Mar 12, 2016 17:18:24 GMT
Thanks for the quick response - gave me the reassurance to take 'em all out. Lights still work, engine still runs - happy days.
