Post by zeitgeist on Feb 19, 2016 0:40:42 GMT
I am getting ready to order the last few parts for completing the steering rack and column rebuild. Are the R version tie rod ends needed or worth the price compared to stock NB tie rod ends? www.flyinmiata.com/r-package-tie-rod-ends.htmlI plan to use stock replacement inner tie rods. Also does anyone know of a source for new universal joint that connects the column to the rack. This is the lowest joint on the column or the first joint between the column and rack. Mine is fairly beat up and I would like to keep safety issues to a minimum if the joint is available. No luck on Rock Auto and a Mazda dealer site. Lastly is there any poly urethane bushing/mounts for the NB steering rack?
Post by abc123 on Feb 19, 2016 2:00:11 GMT
Miataroadster has a delrin bushing kit for the NB rack.
Post by buildercg on Feb 19, 2016 19:15:09 GMT
Post by zeitgeist on Feb 19, 2016 23:02:37 GMT
Awesome thanks guys. Any idea on the R version outer tie rod ends?
Post by dietcoke on Feb 19, 2016 23:41:50 GMT
V8R makes billet rack bushings for $50. Best choice really.
Post by buildercg on Feb 19, 2016 23:51:36 GMT
Sorry, no idea about the R tie rods. I just received new Moog outers for my '92 rack. They were cheaper than OEM replacement but have OEM fit as far as I understand.
Post by dietcoke on Feb 20, 2016 6:34:32 GMT
Awesome thanks guys. Any idea on the R version outer tie rod ends? The R package rods are angled slightly different to work better with a lowered suspension, and reduce bump steer. They're a good choice.
Post by zeitgeist on Feb 20, 2016 16:45:08 GMT
Awesome thanks guys. Any idea on the R version outer tie rod ends? The R package rods are angled slightly different to work better with a lowered suspension, and reduce bump steer. They're a good choice. Thanks. I wasn't sure if it was the angle or length of the taper shaft that was affecting bump steer.
