Post by Deleted on Sept 4, 2015 13:52:18 GMT
Thought id start a bit of a thread on my car. Ill be posting developments of my car as i try and improve it from the initial build. Bit of background, my car is based on a tR1ke but has the hayabusa engine in. Its slightly longer and wider than the tR1ke. Took me and my dad about 6 months to build. Since the car has been MSVA'd i have lowered the rear end due to it sitting too high. This was pretty straight forward and cheap by using lowering links. At MSVA stage i had buttons on the steering wheel for gear changes. since then i have fitted paddles. One major issue i have come across is getting petrol in and the standard tank brackets not being up to the job, the tanks when full bend the brackets the tanks on the triabusa are larger so not sure if this has anything to do with it but also i have a fuel swirl pot and header tank mounted above the tanks limiting access for the fuel pumps. To over come the issue i have had some different tanks made up which sit behind the seat like the exobusa. Over the winter i intend to fit the tanks and re do the wiring, neaten it up. For now im just trying to get some miles in and enjoy my build
Post by james13009 on Sept 4, 2015 20:03:16 GMT
Looking great Adam, keep them coming
Post by Deleted on Sept 10, 2015 11:29:07 GMT
another mod i'm on with is the hand brake. Ive just taken delivery of a raptor rear caliper This is hydraulic and mechanical all built into one. So need to get some head scratching done to get it mounted and working right. This set up was recommended by the MSVA guy as he knew full well of the issue people have with the usual hi spec set up. Mine was a right pain to get through the test and since then has been poor.
Post by erik on Sept 13, 2015 10:05:37 GMT
Nice caliper! A scooter caliper has hydraulic and mechanical too. They come cheap 2nd hand.
Post by Deleted on Sept 13, 2015 10:34:57 GMT
Yeah but not sure a scooter calliper would be up to the job.
Post by Deleted on Sept 13, 2015 10:49:22 GMT
Stripped the tanks out this morning. I was going to wait till later on in the year to do this but I have a clutch issue and before I upgrade the master cylinder I wanted to get the clutch hose to the right length. The one supplied with the kit was miles to long. I just took the access up in the tunnel. So I want to get that to the right length before I do anything. The car is not great to drive at the mo so figured this needs doing. Problem is to get to it I need to remove the tanks. So might as well do the lot while I'm on ?. As you can see there's a lot of space now at the rear end. The other side is a right mess lol where I ran all the cables and stuff. Considering making some alloy panels up for the rear to tidy it up to the eye.
Post by slugshot on Sept 13, 2015 19:36:47 GMT
How do the new tanks mount ads, will you be cutting through the bulkhead to get a fixing like on the exobusa, can't see from the pic's of the tanks but do they have a long tab along the rear.
Post by Deleted on Sept 13, 2015 19:46:37 GMT
The new tanks have a tab on the front which sits on the seat rail and then one either side which will have spaces and mounted to the floor. Only holes in the bulk head will be for fuel pipes. I'll get some pics up as soon as I have one mounted.
Post by Deleted on Sept 17, 2015 19:40:59 GMT
Mounted one tank tonight. All seems to fit really well and feeds to and from the tank should be straight forward. With the three brackets bolted down it seems pretty solid so not sure any more support is need but will fill the tanks and then review. Once the other thank is in and all plumbed in I can get on with the clutch and tidying the rear end up. Need to get it all done over the next few weeks as moving house so time will be soaked up with decorating
Post by slugshot on Sept 17, 2015 20:57:22 GMT
That's great ads, if the tanks are sat on the ally floor they should be as solid as it gets and much better than relying on the little lugs bolted to the chassis.
Just noticed your seat belts mate, how come there's loads of excess length tie wrapped up.?
Post by Deleted on Sept 18, 2015 6:56:29 GMT
There was loads left on the omp harnesses. Was the same on the rocket. Just tie wrapped them up to stop them flapping about.
Post by slugshot on Sept 18, 2015 11:05:11 GMT
You not got any scissors then
Post by Deleted on Sept 18, 2015 11:11:49 GMT
Lol it's how to stop then fraying that's the problem. Going to get my mum to stick them once the seats are all back in lol
Post by paulh on Sept 18, 2015 19:13:25 GMT
Cut them then melt them with a lighter, takes about ten seconds
Post by Deleted on Sept 18, 2015 20:04:18 GMT
Sounds like a plan
