Post by johnay on Mar 11, 2010 19:23:56 GMT
I am thinking of building a Missile based on the 2.0L Zetec. Will I be the first?
Post by Stiggy on Mar 12, 2010 9:27:01 GMT
Yes you will be the first. There is room for the 2.0 and it's MTX75 trans. The gear link cables will need to be extended or you can bolt an IB5 trans on from a 1.8 on. Same bolt pattern. These are much lighter and you then use standard Focus cables. You would also need the engine cover air scoop as shown in Sonic7 pics. The covers are the same on both cars. I'm am looking forward to seeing one with black GRP and the new bright silver powder coat for the chassis we have. It's aluminium wheel silver and looks great. I've just done a Rocket in it. What colours did you have in mind? Attachments:
Post by johnay on Mar 12, 2010 10:22:53 GMT
I was thinking of all black. I am still looking for a good donor so I might end up with a 1.8
Post by Stiggy on Mar 12, 2010 13:21:27 GMT
1.8 is an easier build and cheaper, you could always tune it later.
Post by johnay on Mar 12, 2010 14:45:41 GMT
1.8 it is then, I was only thinking of the 2.0L for the rear discs.
