POR15
Jul 3, 2015 10:48:50 GMT
Post by bignik on Jul 3, 2015 10:48:50 GMT
Looking to paint my subframes with POR15, any advice would be most greatful!!
POR15
Jul 3, 2015 16:20:34 GMT
via mobile
Post by mj127 on Jul 3, 2015 16:20:34 GMT
That's what I used. Turned out pretty good, although I cannot tell about durability yet. Just be sure to do all of the steps. Degrease, metal prep, paint then top coat.
POR15
Jul 3, 2015 18:08:29 GMT
Post by miket on Jul 3, 2015 18:08:29 GMT
Goes on very easily, spreads well and smooths nicely. I put the leftovers in an old jar and its kept just fine to re-use when needed. Good luck.
POR15
Jul 4, 2015 8:56:59 GMT
Post by dietcoke on Jul 4, 2015 8:56:59 GMT
Will turn grey white with sun exposure.
POR15
Jul 4, 2015 18:12:32 GMT
Post by jon on Jul 4, 2015 18:12:32 GMT
Be sure to use in a properly ventilated area. I wore a painters respirator and by the end had a box fan blowing too. It is nasty stuff.
I also did the 3 step process. Worked well. I got a quart of it, turned out to be a lot more than I needed.
POR15
Jul 5, 2015 8:12:39 GMT
via mobile
Post by tom on Jul 5, 2015 8:12:39 GMT
I used POR 15 too, seemed to go on well and coverage was good. It isn't UV stable so you need to topcoat as well. I went for the satin black topcoat that they do which looked pretty good. I used their 'prep and ready' before hand (as well as a lot of time de-rusting with an angle grinder and wire brush)
If you do use POR 15 I recommend only dispensing and using a little at a time(I think the destructions suggest that) once it starts to go off it thickens which can start to leave brush marks. Also buy lots of brushes and bin them when it starts to go off.
It seems very hard once dry so should be nice and durable as long as you follow their guidelines.
Post by jon on Jul 5, 2015 23:58:14 GMT
You guys think it is necessary to top coat the sub frames? They shouldn't see much sun, and are only slightly visible. My control arms are power coated.
POR15
Jul 6, 2015 3:47:48 GMT
Post by gwnwar on Jul 6, 2015 3:47:48 GMT
You have it apart just do it..
