Post by Tim Kerr on Sept 7, 2010 20:34:07 GMT
Just had my Rocket on the scales. Needs to go on a diet!!! Just as well i have a few leightweight mods planned for the winter... Watch this space for the winter modifications Build Diary after my final track day.
mattsmev
It's only Rocket science...
Post by mattsmev on Sept 8, 2010 7:44:48 GMT
Never mind, you have more than enough power to make up for the extra weight.
Just for reference, as far as i can tell (i have done my own corner weights so it not as precise as yours) my 1.6 focus weighs 510kg. I don't have aluminium uprights (mine are steel and very heavy), i don't have a light weight battery. I have also changed my floor covering over the summer to something lighter since i last weighed it.
Mattsmev
Post by Tim Kerr on Sept 8, 2010 9:02:08 GMT
Thats intersting to know Matt. I also have teh heavy front uprights but do have a lightweight battery. Not sure if the Throttle bodies work out heavier or not. Think i am going to change the seats though for GPR!
Post by dinosaurjuice on Sept 8, 2010 14:10:39 GMT
i Think 582 is a good weight for a rocket with comfy seats and iron engine. im sure you could get it under 550 with some lighter seats and wheels...
Just as a comparison D'ocket weighs about 650kg's. with a chunky battery and very heavy wheels.
Post by The Joker on Sept 8, 2010 21:41:23 GMT
Interesting. Need to weigh mine but I'm guessing its also 550Kg+. Heavy uprights, heavy battery. Not sure what the weight on the MAC is as mine says 484Kg ; wishful thinking but more than likely a typo? I would think that throttle bodies work out at a simlar weight to the standard inlet.
Post by simon on Sept 9, 2010 23:15:53 GMT
I'm hoping to get mine under 500KG's. I'm starting to think that might not be practically possible. ST170, ally uprights, lightweight battery, GRP seats, Rota Subzero wheels. How much fuel did you have in it when it was weighed? ( clutching at straws now :
Post by brownie on Sept 10, 2010 9:00:54 GMT
Under 500kg with the St170 steel lump in it is prob impossible. Matt's car with 1.6l alloy block is still over 500kg. :-(
Post by Tim Kerr on Sept 10, 2010 11:15:26 GMT
I had 20ltrs of fuel in her!
Post by s t o n i c on Sept 10, 2010 16:13:56 GMT
When I ran my Sonic sans bodywork and lights at the AMM day, it wascoming in at 465 kg. I've alloy uprights and light wheels. Am adding body work at present sointeresting to see what it comes in at. Am expecting it to be not verymuch over the 520 mark. Have the ST170 and 6 speed box.
The rear upright is darn heavy. If there was a way of making that out of lighter material you could defn save kg's
