Post by Deleted on Feb 13, 2015 10:53:20 GMT
So I have a question for the Mevabusa builders.
What Diff are you using? What ratio is it, and can you alter the ratio and overall speed to a certain degree with different sprockets?
What I need to know is if I fit an LSD Chain Diff for say a Sierra so 3.14 ratio, and my engine is revving high but not producing much speed, can I alter how this works simply by fitting smaller or bigger rear sprockets?
i'm totally lost on the understanding of differentials and what is going to work best on a 1000cc V-Twin engine.
Nick
Post by marshabusa on Feb 18, 2015 18:36:57 GMT
Hey Nick, I am using the Radical/quaife LSD chain drive differential, with integral reverse. An absolutelty brilliant pice of engineering. Drive ratio's are very much adjustable via the fitment of different sprockets. Both forward and rear sprockets can be changed. Pushihng for higher top speeds reduces acceleration, and opting for quicker acceleration times reduces overall top speed. Consideration into main uses for the vehicle need considered for best ratio's. Again though it's not too difficult to chage ratio's later, especially with the split type rear sprockets. Here is a useful link to help playing with different power plants and drive ratio's. They can also supply differnt diffs. www.westgarage.co.uk/calculators/calculators.htmlMy diff can be seen on page 6 of my build diary. I hope this helps answer your questions. Dean
Post by Deleted on Feb 19, 2015 22:16:53 GMT
Just took a brief look over the pictures on the build and photo bucket, this is exactly what I want. I look forward to seeing it in the flesh
Many thanks, you have changed my direction and thoughts to diff now
Nick
Post by hightower on Feb 20, 2015 8:09:41 GMT
Post by Deleted on Feb 20, 2015 8:49:12 GMT
I think this diff is in the region of £1400 and the other chain diff is up around the £2000
Sent from my Nexus 5 using proboards
Post by hightower on Feb 20, 2015 11:17:14 GMT
£3500 custom diff I was told off the guy I bought if off for £500 bargain. I don't no much about them tho,it was in his huyabusa race car.
Post by Stiggy on Feb 20, 2015 11:28:43 GMT
you have a forward/reverse unit I believe.
Post by hightower on Feb 20, 2015 11:39:21 GMT
Yes Stuart 6 forward gears 6 reverse gears, may even attempt world reverse record haha.its 102 mph I believe
Post by mawdo81 on Feb 20, 2015 13:06:03 GMT
Hope you have big mirrors, and bigger balls!
Post by hightower on Feb 20, 2015 13:35:20 GMT
Haha mawdo I was just saying its possible but highly unlikely I'd bet its mega hard to get much over 40 mph.
Post by Deleted on Feb 20, 2015 14:36:14 GMT
Post by Deleted on Mar 1, 2015 21:16:51 GMT
What pound springs are fitted on the Mevabusa front and rear?
